After 6 months trouble free...ITS STARTED AGAIN !!!!!
- Re: After 6 months trouble free...ITS STARTED AGAI...
18-01-2010 9:05 AM
Download speedachieved during the test was - 372 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :960 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
Telephone number:
01244******
Phone exchange:
CONNAHS QUAY
Estimated line speed:
4.0 - Checked on 2009-04-04 17:29:32
Current line speed:
500
Re: After 6 months trouble free...ITS STARTED AGAIN !!!!!
18-01-2010 9:14 AM
Quote Your DSL Connection Rate :960 Kbps(DOWN-STREAM)
That's your problem, you are connecting at a low speed to the exchange.
Can you give us the rest of the stats from your router? If you go to this link and give us the stats from the page it'll help out:
http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0
18-01-2010 9:16 AM
Link Information
Uptime: 0 days, 6:50:58
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 960
Output Power (Up/Down) [dBm]: 11.5 / 18.0
Line Attenuation (Up/Down) [dB]: 20.0 / 34.0
SN Margin (Up/Down) [dB]: 7.0 / 10.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Framing (Local/Remote): 57 / 0
Loss of Signal (Local/Remote): 5 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 18 / 0
FEC Errors (Up/Down): 18,074 / 156
CRC Errors (Up/Down): 18,074 / 7
HEC Errors (Up/Down): 9,718 / 4
18-01-2010 1:51 PM
18-01-2010 3:08 PM
p.s tried a different grey lead but still the same .
18-01-2010 3:17 PM
Is the router plugged into the master socket? Have you tried an alternate filter? Are any extension leads in use? Are any other phone points in use filtered.
If the answers are yes, yes, no, yes then we need to investigate this as an intermittent connection rather than a speed issue as it'll be the connection dropping causing the speed problems.
18-01-2010 3:33 PM
http://www.adslnation.com/phpapps/catalog/popup_image.php?pID=105&osCsid=sod3d09rit2vhrjaekvfb1j4d1
3. No extension leads in use
4. Three other standard phone in use all plugged into filters...(kitchen, main bedroom and garage)
18-01-2010 3:36 PM
18-01-2010 3:40 PM
18-01-2010 3:48 PM
18-01-2010 3:52 PM
Your DSL connection is down.
Verify if your Thomson Gateway is correctly connected to your DSL line. For more information consult your documentation.
18-01-2010 3:55 PM
18-01-2010 4:07 PM
18-01-2010 8:53 PM
Download speedachieved during the test was - 226 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Your DSL Connection Rate :2528 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 250 Kbps
DSL Connection
Link Information
Uptime: 0 days, 4:00:05
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,528
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 88.96
Output Power (Up/Down) [dBm]: 11.0 / 18.5
Line Attenuation (Up/Down) [dB]: 19.0 / 33.0
SN Margin (Up/Down) [dB]: 13.0 / 15.5
FEC Errors (Up/Down): 4 / 135
CRC Errors (Up/Down): 4 / 11
HEC Errors (Up/Down): 4 / 10
18-01-2010 8:57 PM
Any further problems and I'd be using a filter in the Test Socket.
