Adsl2+ active or not?
- Adsl2+ active or not?
04-04-2012 9:06 AM
Re: Adsl2+ active or not?
04-04-2012 10:01 AM
Have you checked your sync rates?
Also if you run the BT speedtester you can tell if you've been moved to 21CN ADSL2+
On 20CN it doesn't test upload, on 21CN it does.
04-04-2012 10:05 AM
04-04-2012 10:31 AM
The first part of test I only got 99kbps! It didn't do upload speed for that part, this is from using the adsl & fibre to the cabinet (FTTC) diagnostics tab
04-04-2012 11:18 AM
I think you'll need to ask again for the move to ADSL2+.
Why you got such a slow speed test result is another mystery!
Could you run this test please: http://www.thinkbroadband.com/speedtest.html and post the result.
04-04-2012 11:28 AM
04-04-2012 11:37 AM
Quote from: paulg123 Hello so not sure if adsl2+ is activated for me or not yet, the ticket for the order to change me over has been closed and in another ticket that was opened for cancelling max premium it says my broadband order is due to complete by midnight 03/04/12? Not sure if that is just referring to confirmation that that max premium removal complete or it's referring to adsl2+ being activated
The one on 03/04 was for Max Premium. As for the upgrade, the ticket said "We expect this to happen within the next 5 weeks." so I'll see if I can place it earlier for you.
Jojo
04-04-2012 11:48 AM
04-04-2012 11:49 AM
Quote from: paulg123 done thinkbroadband result
That isn't your result. When the test completes you need to click the "I live in the UK and my ISP is selected above" button. This will then give you the results page.
Scroll down and copy all the code in the BBCode (for forums; not supported on thinkbroadband forums) box which will look something like
[url=http://www.thinkbroadband.com/speedtest/results/id/13335363073027828594.html][img]http://www.thinkbroadband.com/speedtest/button/13335363073027828594.png[/img][/url]
This will then appear as
in your post.
04-04-2012 12:02 PM
The order was placed yesterday as part of bulk upgrades and is due to complete on the 23rd.
Jojo
23-04-2012 2:01 PM
Is it because I've just had a go on my iPhone and the wireless connection is limited to a set speed?
speed is same on my pc, i know that moving to adsl2+ will have the training period with the speed going up and down but its stayed dead on the old speed, am i capped at the moment?
23-04-2012 5:14 PM
something has changed i broke the 7 meg barriewr and hitting 14-15 meg at moment progress
couple of other things, is interleaving still off and could i have the cap removed on the upload speed if possible?
23-04-2012 8:36 PM
Interleaving is off and I've placed the order to uncap the upload. I've confirmed this via ticket.
Jojo
23-04-2012 9:02 PM
24-04-2012 8:27 AM
