Activation time
- Activation time
Re: Activation time
16-04-2009 8:24 PM
My front door, socket inside hallway, then the line comes through to the living room and it's that socket where it's plugged in. I don't think it will reach the socket at the front door though
Edit: I put the router in the hallway to try and couldn't even get it to synch, also if it did sync i doubt it'd reach the pc and it'd mean having to thread a cable under the living room door.
It also means i'd have a cable behind the front door "From the master socket to the only place i could put the router at the bottom of the stairs."
Question is, do i have to use the first socket in the house or can i use the one in the living room?
Could be a bit of a pain trying to find a solution to this if i have to use first socket in the house ^^
Thanks again
Re: Activation time
16-04-2009 8:43 PM
1)Have you any phones on this system?
2) you mentioned filters, there should not be any filter on the line to the router, the supplied filters have two sockets, one for a phone and one for a router. The router must not pass through the phone side of the filter.
3) your first post to say the least alarmed me in your description
4) it could work if you have a good line, but it is no where ideal
Sorry
Re: Activation time
16-04-2009 8:55 PM
There's nothing except a microfilter in each socket, and the wire connecting the DSL part of the microfilter to the DSL socket of the router.
Pretty puzzled and couldn't get it to sync when i was testing it in the master socket so i can only presume as orbrey said that it's not completed yet.
Really hope it doesn't need to be in the master socket
Thanks again for the help
Re: Activation time
16-04-2009 11:38 PM
Apologies if I've missed the point here, I assume it's the connection between the router and the PC that's not long enough?
Re: Activation time
16-04-2009 11:47 PM
http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=5326
Cuts out all that ugly wiring and i think so people have said they put a couple of ms on latency but if your not a gamer that shouldn't be a issue
Mark
Re: Activation time
17-04-2009 8:03 AM
Quote from: orbrey Apologies if I've missed the point here, I assume it's the connection between the router and the PC that's not long enough?
Yeah, if i had to set it up in hallway then it wouldn't reach the pc in the living room ><
i suppose i could connect the pc via wireless if has to be in master socket but i would REALLY prefer not to have the cables in the hallway.
Also, i have no idea what i do with BroadbandBuyer PL-85PE Homeplug 85Mbps Ethernet Starter Kit,, ><
Thanks as always for the help
Tj
Edited for typo/s
Re: Activation time
17-04-2009 8:12 AM
Re: Activation time
17-04-2009 8:23 AM
Can't get it to sync in living room or front hallway at all this morning so i just hope it's down to the work not being finished and not a fault.
Is there anyway you can check if BT have finished the work at my exchange yet?
Edit: got it to sync in master socket and connected a laptop to see if the sync speed was any different.
Uptime: 0 days, 0:14:39
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 160
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 2.00
Output Power (Up/Down) [dBm]: 12.0 / 13.0
Line Attenuation (Up/Down) [dB]: 30.5 / 53.0
SN Margin (Up/Down) [dB]: 16.0 / 2.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 6,990
CRC Errors (Up/Down): 0 / 4
HEC Errors (Up/Down): 0 / 3
Virtually the same so i think it's a case of waiting to see if speed improves.
Thanks again guys.
Re: Activation time
17-04-2009 9:27 AM
Re: Activation time
17-04-2009 9:40 AM
Re: Activation time
17-04-2009 9:44 AM
Quote Bandwidth (Up/Down) [kbps/kbps]: 448 / 160
There 'aint no improving that by waiting - this is a classic symptom of internal wiring faults.
160Kbps downstream is the 'absolute minimum' sync. Even on a very long and noisy line you should get AT LEAST 512Kbs.
Does your master socket have a removable split-faceplate? If so, remove the bottom half and plug the router back into the test socket and see what it syncs like there.
B.
EDIT: Added pic of Master test socket
Re: Activation time
17-04-2009 10:25 AM
Also yes i have access to the internet when browsing.. I think if it is down to fault wiring it's the BT engineers fault as instead of a complete new line he "botched" the job so to speak and just reattached the old line where it came into the house with a new extension to the sockets etc.
Anyways will see if there's any improvement by using master socket.
Thanks again
Tj
Edit: I removed the faceplate off the master socket, put a microfilter in the test socket and connected the router to it....I couldn't even get it to sync.
I can only hope that it's because it's because the work in the exchange isn't fully completed because i don't want to have to pay BT 120£ to fix a problem that "if it is a wiring fault," they caused.
Edit 2: When it does sync, pings are fine, all below 60ms.. Hope this helps
Re: Activation time
17-04-2009 11:27 AM
Bandwidth (Up/Down) [kbps/kbps]: 448 / 640
"If" i can get it to sync on test socket i'll try on there as well.
Edit: After posting this lost sync again Will just wait until tomorrow after 12pm to see if it's ok then.
Re: Activation time
17-04-2009 12:46 PM
Re: Activation time
17-04-2009 12:59 PM
If only the one in the hallway has a removable lower half, remove that and check for dial tone in the test socket and the other socket.
Hopefully it will only the one in the hallway that works when the lower half(s) are removed, otherwise as Matt says it will get interesting!
Can you also tell us if there are wires connected to the back of the removable lower half please.
