Activated?
- Activated?
Activated?
12-05-2012 5:49 PM
Just wondering when I'll be switched on and ready to go? My router arrived on Wednesday. Checking the order tracker and it's been on ' checking your line ' since the hardware arrived..
Message 1 of 5
(1,045 Views)
4 REPLIES 4
Re: Activated?
12-05-2012 8:09 PM
Welcome to the forum Thumb866.
Have you tried connecting up your router and see what lights come on?
Do you know your estimated activation date?
Message 2 of 5
(318 Views)
Re: Activated?
12-05-2012 11:05 PM
I don't really want to set up and connect the router until I get the green light from pn that it's ready to use. I don't know my activation date? How long does it usually take for the broadband to become active after one receives their router?
Message 3 of 5
(318 Views)
Re: Activated?
12-05-2012 11:43 PM
I think the router is delivered just before the order is due to complete. Why not give the CSC a ring on 0800 432 0200 (or 0345 140 0200)? They are available 24x7 and should be able to check the status of your order.
David
Message 4 of 5
(318 Views)
Re: Activated?
13-05-2012 5:02 AM
Quote from: Thumb866 Just wondering when I'll be switched on and ready to go? My router arrived on Wednesday. Checking the order tracker and it's been on ' checking your line ' since the hardware arrived..
Hi Thumb866,
Your broadband activation will complete by midnight on 16/05/2012.
Hope this helps
Message 5 of 5
(318 Views)
