Access to youtube and facebook on my apple mac is blocked
- Access to youtube and facebook on my apple mac is ...
08-08-2011 2:52 PM
Re: Access to youtube and facebook on my apple mac is blocked
08-08-2011 3:09 PM
Can you confirm if you can ping both youtube.com and facebook.com from your Mac? You will need to open a Terminal window (Applications Folder -> Utilities -> Terminal) and type:
ping www.youtube.com
Or:
ping www.facebook.com
08-08-2011 3:17 PM
08-08-2011 3:19 PM
(error number? timeout? etc.)
08-08-2011 3:22 PM
Quote from: robyn Yes. I can access them from your links.
Just tried the terminal thing now and it just keeps continuing like this Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
Request timeout for icmp_seq 6
08-08-2011 3:23 PM
Now and again I can get access to youtube, but once something is loaded and I do another search I lose access again. This is driving me crazy.
I have tried reinstalling flash player, changing the MTU setting to 1400 as recommended, turning on and off the router, different browsers (safari & google chrome), removing DNS server addresses - all to no avail. Please can you help? I am really stuck with this. :
08-08-2011 3:37 PM
Are you able to connect elsewhere (google? etc.)?
are you connecting to your network via Wireless or Wired?
What router do you have?
have you tried accessing the sites on the PC at the same time as you cannot on your mac?
Is anything else running (Time Machine?) - this could have an affect on network performance
08-08-2011 3:47 PM
Are you able to connect elsewhere (google? etc.)? - My problems only apply to youtube and facebook
are you connecting to your network via Wireless or Wired? - Wireless - via Airport
What router do you have? - TP-Link
have you tried accessing the sites on the PC at the same time as you cannot on your mac? -Yes - no problem
Is anything else running (Time Machine?) - this could have an affect on network performance - No all other programs are closed
Occasionally I can get access and then when I do another search the connection just goes on youtube
08-08-2011 4:06 PM
Quote changing the MTU setting to 1400 as recommended,
1400 is pretty low, where did you find that recommendation? 1492 i believe is the 'recommended' for ADSL connections - setting 1500 will have no adverse affects.
Quote I am really stuck with this.
I can see why, very strange issue indeed, by "removing DNS addresses" you mean you now have none set?
can you get to www.youtube.com/html5 - try running the HTML5 version of the site if you can and see if the problem remains.
Regards
08-08-2011 4:53 PM
have tried www.youtube.com/html5 - this doesn't work either. I really appreciate your help ..................................... any other suggestions?
08-08-2011 4:57 PM
traceroute www.youtube.com
And press "Enter" on your keyboard. We will need to see the full output for this one so take a screengrab or copy and paste the text directly from the Terminal window.
08-08-2011 5:33 PM
traceroute to www.youtube.com (78.16.49.15), 64 hops max, 52 byte packets
1 192.168.1.1 (192.168.1.1) 1.095 ms 0.866 ms 1.287 ms
2 lo0-central4.ptn-ag04.plus.net (195.166.130.82) 22.663 ms 17.832 ms 16.067 ms
3 gi2-23-442.ptn-gw02.plus.net (84.93.253.75) 16.782 ms 15.723 ms 14.990 ms
4 linx-gw.uk.esat.net (195.66.226.65) 15.337 ms 15.543 ms 16.041 ms
5 pos1-3-1.br002.cwt.esat.net (193.95.131.49) 32.269 ms 32.550 ms 32.127 ms
6 teng0-0-0-3.core001.cwt.esat.net (193.95.129.56) 33.145 ms 33.191 ms 32.052 ms
7 teng0-1-0-0.rt502.cwt.esat.net (193.95.129.70) 32.630 ms 33.544 ms
teng0-0-0-0.rt501.cwt.esat.net (193.95.129.64) 32.898 ms
8 gige1-0-0.bas508.cwt.btireland.net (193.95.136.117) 31.995 ms 32.580 ms 32.723 ms
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
Does this help?? Thanks
08-08-2011 5:38 PM
C:\Users\Jim>tracert www.youtube.com
Tracing route to youtube-ui.l.google.com [74.125.230.135]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 33 ms 32 ms 33 ms lo0-central2.thn-ag2.plus.net [195.166.128.230]
3 33 ms 32 ms 31 ms gi1-14-221.thn-gw1.plus.net [84.92.6.200]
4 31 ms 32 ms 31 ms 72.14.222.97
5 37 ms 32 ms 33 ms 64.233.175.27
6 32 ms 32 ms 32 ms 209.85.251.202
7 33 ms 33 ms 32 ms 74.125.230.135
Trace complete.
08-08-2011 5:46 PM
08-08-2011 5:51 PM
Can you try the same thing from the PC
