AVG updates restricted on BBYW2
- AVG updates restricted on BBYW2
- « Previous
- 1
- 2
- Next »
Re: AVG updates restricted on BBYW2
09-01-2009 11:00 AM
I believe they are both included in the "download server" rate limit.
Have speed been better since the original post was raised?
09-01-2009 11:54 AM
A lot of software companies use the Akamai CDN to reduce loads on their webservers and speed up site performance/download speed by caching content on a server cluster physically nearer the customer (technique known as edge caching)
09-01-2009 8:12 PM
09-01-2009 8:17 PM
09-01-2009 8:43 PM
Not sure if AVG tells you what server if trying to obtain the update from but it might be worth doing the following:
Get the full server URL
In XP:
Start > Run and type cmd
Type ping and then the server name and domain
Get the IP and head to http://www.ripe.net
Stick the IP in the box on the top right and click Go
If its registered to Akamai it will say below and that is the cause of the issue
09-01-2009 8:51 PM
Next Section
Query the RIPE Database
Search for
Switch to the RIPE TEST Database
% This is the RIPE Whois query server #1.
% The objects are in RPSL format.
% Rights restricted by copyright.
% See http://www.ripe.net/db/copyright.html
% Note: This output has been filtered.
% To receive output for a database update, use the "-B" flag.
% Information related to '193.86.3.32 - 193.86.3.63'
inetnum: 193.86.3.32 - 193.86.3.63
netname: HC-GRISOFT2
descr: GRISOFT, s.r.o.
descr: Praha
country: CZ
admin-c: Gcr10-RIPE
tech-c: Gcr10-RIPE
status: ASSIGNED PA "status:" definitions
mnt-by: GTSCZ-MNT
source: RIPE # Filtered
role: Grisoft contact role
address: GRISOFT, s.r.o.
address: Lidicka 31
address: 602 00 Brno
address: Czech Republic
admin-c: RP4336-RIPE
tech-c: JT1151-RIPE
e-mail: info@grisoft.com
nic-hdl: Gcr10-RIPE
mnt-by: GTSCZ-MNT
% Information related to '193.86.0.0/16AS2819'
route: 193.86.0.0/16
descr: CZNET-A
origin: AS2819
mnt-by: GTSCZ-A-MNT
Means sod all to me
09-01-2009 8:59 PM
Very odd.
09-01-2009 10:25 PM
If downloads slow down it's not necessarily PN throttling the site.
(Some sites restrict the rate at which you can download from them or slow down at busy times - Ahead Nero's download servers used to slow to a crawl whenever an update to Nero was released).
11-01-2009 5:24 PM
Bear in mind that AVG is quite popular so as paul said it could just be sheer load.
Personally I prefer Avast! myself.
12-01-2009 11:20 AM
- « Previous
- 1
- 2
- Next »
