AVG Anti-Virus Free Edition 8.0
- AVG Anti-Virus Free Edition 8.0
Re: AVG Anti-Virus Free Edition 8.0
28-04-2008 8:29 AM
Quote from: poppy I tried Avast yesterday (in desperation) but couldn't find the e-mail scanner wizard which should (according to the blurb) have been in Start/All Programmes. Therefore I had to ditch it. It is certainly a lighter programme and if I had been in a better frame of mind I could have fathomed it probably. However, do you have any suggestions about where this wizard had hidden itself so that I could have retrieved e-mails in WM (it was just giving error messages).
I still have the setup icon on my computer (downloaded from Download.com).
It is in avast! On-Access Scanner, See Screen Shot.
28-04-2008 9:20 AM
28-04-2008 9:47 AM
ive just installed v8.0 on a vista comp and although it installed ok, it wont run. it brings up an error saying failed to start because its side by side config is incorrect. please see application event log for more details..
HELP!!!
Craig p
28-04-2008 10:31 AM
Tony
28-04-2008 12:37 PM
Did some initial set ups, scheduled the daily run for 10:00 then set it to do a complete computer scan. Went to the shops 5 miles away, did some banking, went to the post office, and bought some bread (not from the post office! !) came home 5 miles, and it was still running..... Not worried.... went "online" did some more banking, checked my emails, and sent a couple, still running, final result came in with a "popup" saying the complete scan was finished .... checked the results on the control panel
Total objects scanned 724,000
Time taken 2hrs 34 mins 13 seconds
Infections 0
Spyware 0
Warnings 52 (these were "cookies" and trackers)
Removed the infections, and then had a cup of tea and my second breakfast ! feeling quite chuffed!..
Sorry for those who have problems, but I well recommend this AVG FREE 8.0
(Just one point, I did do a manual un-install of AVG 7.5 and AVGAS before doing the install, and I am running XP SP2 80 gb hdd 256 mb RAM)
Good luck
Shutter
Oh just remembered, that while doing the initial scan started by me, the scheduled scan was started, and continued after the initial scan, so it was doing two scans at the same time!
28-04-2008 12:49 PM
Presumably you have no other anti-virus running? The other thing is, did you take off 7.5 first? Strictly speaking, it isn't necessary but a full uninstall of everything might do the trick. Good luck and let us know how you get on.
28-04-2008 3:25 PM
Quote from: nadger
Quote from: ste I prefer avast to this. avg free doesn't have a web shield, whereas avast does.
Again this does exist in the professional version of AVG 8.0 - be interesting to see how much they'll try to charge me on 1st December.
but not in the free version.
28-04-2008 6:31 PM
I am helping my friend out with this (she uses Sky) and I have followed the advice from FAQ religiously but with no joy.
Within OE the servers are 127.0.0.1 (as advised), ports 5100 for pop and 5200 for smtp (both unsecured as advised).
Within AVG the pop settings are fixed host pop.gmail.com:995 with the local port to match OE i.e. 5100.
SMTP is set to fixed smtp.gmail.com:465 with port 5200. Both have SSL activated. I have been able to send and receive e-mails but the scanner counter/certification text is not functional. I just wondered if there was somebody who had tried this and succeeded, particularly as Gmail is so popular.
28-04-2008 6:52 PM
Didn't have to change a thing from standard gmail recommended settings:
servers: pop.gmail.com & smtp.gmail.com
Incoming SSL port 995 Outgoing SSL port 465
That's all!
28-04-2008 7:20 PM
Are your secure ports 995/465 configured in the scanner itself or in the Outlook setting? The advice that I gleaned was as above.
28-04-2008 7:25 PM
Craig p
29-04-2008 7:35 AM
I have now managed to receive e-mails from gmail and they are certified and counted. AVG is therefore communicating with the gmail servers with the ports set to 465 for smtp and 995 for pop (both secured). All relevant boxes ticked.
OE has the loop back servers 127.0.0.1 with both ports set to match AVG (not secured). Only problem now is that I can't actually send e-mails and this is the error message:
The connection to the server has failed. Subject 'test', Account: 'gmail', Server: '127.0.0.1', Protocol: SMTP, Port: 465, Secure(SSL): No, Socket Error: 10061, Error Number: 0x800CCC0E.
I have posted on the AVG forum with no luck so I am hoping that someone will be able to tell me why they are not going. We had it set up fine with AVG 7.5.
29-04-2008 9:15 AM
29-04-2008 9:32 AM
I don't understand why you have not had to use loopback - did you install the plugin for Outlook? Certainly this is what is advised in the FAQ for setting up a secure connection within OE/WM.
Thank you for posting and trying to help - much appreciated.
29-04-2008 9:48 AM
Could your previous loopback setups have left some debris behind?
