ASUS RT-N66U 'Dark Knight' & TP-Link TD-8817
- ASUS RT-N66U 'Dark Knight' & TP-Link TD-8817
27-02-2013 11:22 AM
I was wondering if anyone has any experience of the setup as mentioned in the subject line (ASUS RT-N66U 'Dark Knight' & TP-Link TD-8817)? My broadband got activated today - I'm aware that the modem has to be in bridged/bridging mode. Do I have to set the modem up with my plus.net connection information (I presume so but would rather be sure) which my Asus then picks up?
Thanks in advance,
JJ
Thanks in advance,
JJ
Message 1 of 6
(3,296 Views)
5 REPLIES 5
Re: ASUS RT-N66U 'Dark Knight' & TP-Link TD-8817
27-02-2013 11:31 AM
i just got the asus and fibre yesterday mine was just a case of plugging asus into modem and it finds your connection and the rest is self explanatory brilliant router get this wireless
Message 2 of 6
(759 Views)
27-02-2013 11:35 AM
sorry i just notice u are using the tplink
Message 3 of 6
(759 Views)
27-02-2013 11:39 AM
I'll give it a try - should hopefully be a similar scenario
Thanks,
JJ
I lost my speedtest image... gutted
Thanks,
JJ
Message 4 of 6
(759 Views)
27-02-2013 11:45 AM
With the TP-Link in bridge mode, the N66u should pick up the connection - make sure you're connected via the WAN port on the Asus N66U. The run the quick internet setup and hopefully it will pick up the connection.
Message 5 of 6
(759 Views)
27-08-2013 2:02 PM
Hi MrJasinski, did you get this working and are you happy with the set-up? I'm also thinking of getting the TP-Link/Asus combination.
Bob
Bob
Message 6 of 6
(759 Views)
