ASUS DSL-N66U / DSL-AC68U - Information please
kitz
Re: ASUS DSL-N66U / DSL-AC68U - Information please
(If you mean the info you gave me earlier)
I was compiling a report for someone and was trying to make a good case that a certain manufacturer fell miles behind every other VDSL modem when it came to info you could get from a certain router.
redbull2k14
how does it stack up at the moment?
kitz
The (Asus) does ok when it comes to info about the line.  OK theres a bug in there..  but its not completely useless, and still provides a heck of a lot of info than a certain other.
__
ETA
Line stability is another matter though and not what Id been asked to report on. Wink
If you want line performance I will suggest you look for a router with a DSL  BCM chipset
redbull2k14
ok i got the dsl-ac68u and i believe its bcm in the log it has this eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.86 (r456083)
goldenfibre
Seasoned Pro
Fixes: 12
Asus never sell any BCM chipset, never is. All Asus routers come with MediaTek chipset. Kitz will tell you that Asus does not have any BCM chipset. Check here: http://forum.kitz.co.uk/index.php?topic=14436.0
pwatson
Mediatek 7510 and 7550 if the interweb is to be believed...
ejs
Aspiring Hero
Fixes: 25
Quote from: redbull2k14
So the DSL-AC68U has Broadcom ethernet (LAN) and Broadcom WiFi, that doesn't mean it's got Broadcom DSL. Looking at the firmware, the DSL-AC68U seems to be an unusual device, since the firmware contains two filesystems for different CPU architectures (one ARM, the other MIPS). Its "dual dedicated CPUs" must be each running a separate operating system.
redbull2k14
ok heres a list that i got from telnet im trying to get my line stats with my new modem router
ASUSWRT DSL-AC68U_3.0.0.4 Mon Aug 25 03:53:12 UTC 2014
admin@DSL-AC68U:/tmp/home/root#
3ginfo.sh                  du                          lsmod                      setconsole
ATE                        e2fsck                      lsusb                      setup_dnsmq
[                          eapd                        madwimax                    setuprsa.sh
[[                          ebtables                    md5sum                      sh
acsd                        echo                        mdev                        sigmon
ad                          egrep                      memalloc                    sleep
add_account                ejusb                      minidlna                    smbd
add_folder                  email                      miniupnpd                  smbpasswd
add_multi_routes            emf                        mkdir                      sort
adslate                    env                        mke2fs                      spectrum
afpd                        epi_ttcp                    mkfs.ext2                  strings
afppasswd                  et                          mkfs.ext3                  swapoff
app_base_library.sh        ether-wake                  mkhfs                      swapon
app_base_link.sh            expr                        mknod                      switchmode
app_base_packages.sh        ez-ipupdate                mkntfs                      sync
app_cancel.sh              fdisk                      mkswap                      sysinfo
app_check_folder.sh        fgrep                      mod_account                syslogd
app_check_pool.sh          find                        mod_folder                  tail
app_fsck.sh                find_modem_node.sh          modem_enable.sh            tar
app_fsck_all.sh            find_modem_type.sh          modem_signal.sh            taskset
app_get_field.sh            firmware_check              modify_if_exist_new_folder  tc
app_init_run.sh            flock                      modprobe                    tcpcheck
app_install.sh              free                        more                        telnet
app_move_to_pool.sh        free_caches                mount                      telnetd
app_remove.sh              fsck.ext2                  mt-daapd                    test
app_set_enabled.sh          fsck.ext3                  mtd-erase2                  test_disk1
app_stop.sh                fsck.minix                  mtd-unlock                  test_disk2
app_switch.sh              fsync                      mtd-write2                  test_endian
app_update.sh              ftpget                      mv                          test_if_exist_account
app_upgrade.sh              ftpput                      nas                        test_if_exist_share
arp                        gctwimax                    netstat                    test_of_var_files
arpstorm                    gencert.sh                  netstat-nat                test_share
ash                        get_account_list            networkmap                  test_system
asus_lp                    get_all_folder              nice                        tftp
asus_sd                    get_apps_name              nmbd                        top
asus_sg                    get_folder_list            nohup                      touch
asus_sr                    get_permission              nslookup                    tp_init
asus_tty                    get_phy_speed              ntp                        tr
asus_usb_interface          get_phy_status              ntpclient                  traceroute
asus_usbbcm                get_var_file_name          nvram                      traceroute6
asuswebstorage              gpio                        nvram_erase                true
auto_det                    grep                        openssl                    tune2fs
auto_macclone              gunzip                      openvpn                    u2ec
autodet                    gzip                        ots                        udevtrigger
avahi-daemon                halt                        pc                          udhcpc
awk                        head                        pidof                      udpxy
basename                    hotplug                    ping                        umount
bcrelay                    hotplug2                    ping6                      uname
blkid                      how_many_layer              pppd                        uniconv
brctl                      httpd                      pppoe-relay                unzip
busybox                    hub-ctrl                    pptpctrl                    updown.sh
cat                        icon.ico                    pptpd                      uptime
chat                        icon.large.ico              preinit                    uqmi
check_spectrum.sh          ifconfig                    printf                      usb_modeswitch
chk_app_state              igmpproxy                  ps                          usb_notify
chkhfs                      igs                        psta_monitor                usbled
chkntfs                    infosvr                    public.pem                  usbtest.sh
chmod                      initial_all_var_file        push_log                    usleep
chown                      initial_folder_list        pwd                        vconfig
chpasswd                    initial_var_file            radio                      vi
chpasswd.sh                inotify                    radvd                      vsftpd
clear                      insmod                      rc                          wanduck
cmp                        ionice                      rcheck                      watch
cnid_dbd                    ip                          rdnssd                      watchdog
cnid_metad                  ip6tables                  read_sms                    wc
comgt                      ip6tables-restore          readlink                    webs_update.sh
console                    iptables                    reboot                      webs_upgrade.sh
cp                          iptables-restore            renice                      wget
create_if_no_var_files      iptables-save              req_dsl_drv                which
crond                      kill                        restart_wireless            wimaxc
cru                        killall                    rm                          wimaxd
cut                        klogd                      rmdir                      wl
date                        l2tp-control                rmmod                      wlcconnect
dbd                        l2tpd                      route                      wlconf
dd                          led_ctrl                    rsasign_check              wlcscan
ddns_updated                less                        rstats                      wpa_cli
del_account                lighttpd                    run_app_script              wpa_supplicant
del_folder                  lighttpd-arpping            run_pptpd                  wps_monitor
df                          lighttpd-monitor            run_telnetd                wpsaide
dhcp6c                      lld2d                      scsi-start                  write_3g_ppp_conf
dhcp6s                      lld2d.conf                  scsi-stop                  write_smb_conf
dirname                    ln                          sdparm                      write_webdav_conf
disk_monitor                logger                      sed                        xtables-multi
disk_remove                login                      send_sms                    zcat
dmesg                      lpd                        service                    zcip
dnsmasq                    ls                          set_permission
AndyH
Run:
cat /proc/cpuinfo
That will tell you the chipset. I'm pretty sure Asus use Ralink/MediaTek for their modem routers.
goldenfibre
Seasoned Pro
Fixes: 12
Of course it will be MediaTek chipset.
pwatson
redbull2k14
admin@DSL-AC68U:/tmp/home/root# cat /proc/cpuinfo
Processor      : ARMv7 Processor rev 0 (v7l)
processor      : 0
BogoMIPS        : 1599.07
processor      : 1
BogoMIPS        : 1599.07
Features        : swp half thumb fastmult edsp
CPU implementer : 0x41
CPU architecture: 7
CPU variant    : 0x3
CPU part        : 0xc09
CPU revision    : 0
Hardware        : Northstar Prototype
Revision        : 0000
Serial          : 0000000000000000
how can i pull my line stats. adslphxcmd info --show does not work
goldenfibre
Seasoned Pro
Fixes: 12
ASUSWRT DSL-AC68U are very bad hardware for VDSL that will trigger DLM. There is lot of problem arise here: http://forums.overclockers.co.uk/showthread.php?p=26944969 and http://forums.overclockers.co.uk/showthread.php?t=18625061
DSL-AC68U uses a MediaTek chipset for its DSL, this has lineage back to the Trendchip chipsets. Trendchips have a bad rep for poor reliability especially on bad and/or long lines. I would recommend to return the DSL-AC68U as not fit for purpose and use a modem/router in bridge mode and the ASUS RT-AC68U wireless router instead?
redbull2k14
i have already taken back 2 dsl n66u's and then got this one. the thing is i think if we are all going to take them back how are they ever going to fix the bugs, with out us. if we stick with it the more things will get fixed and then they can concentrate on new features.
ejs
Aspiring Hero
Fixes: 25
The DSL-AC68U seems to be pretty much a WiFi router and separate VDSL2 modem, but they're just in the same box.
Once you're in telnet in the WiFi router part, you'll need to telnet again to get into the modem, but of course you'll need to work out it's IP address. Try:
cat /proc/net/arp
That should show the IP addresses of all connected devices. You'll have to work out which one is the modem, it'll be one you don't recognise. Then telnet to that IP, and then if you do "cat /proc/cpuinfo", it'll be totally different. Then you'll be able to access the modem stats.
