ASUS DSL-N66U / DSL-AC68U - Information please
- Re: ASUS DSL-N66U / DSL-AC68U - Information pleas...
Re: ASUS DSL-N66U / DSL-AC68U - Information please
22-09-2014 12:31 AM
I was compiling a report for someone and was trying to make a good case that a certain manufacturer fell miles behind every other VDSL modem when it came to info you could get from a certain router.
22-09-2014 12:35 AM
22-09-2014 12:46 AM
__
ETA
Line stability is another matter though and not what Id been asked to report on.
If you want line performance I will suggest you look for a router with a DSL BCM chipset
22-09-2014 1:46 PM
22-09-2014 1:53 PM
22-09-2014 1:59 PM
22-09-2014 9:46 PM
Quote from: redbull2k14 eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.86 (r456083)
So the DSL-AC68U has Broadcom ethernet (LAN) and Broadcom WiFi, that doesn't mean it's got Broadcom DSL. Looking at the firmware, the DSL-AC68U seems to be an unusual device, since the firmware contains two filesystems for different CPU architectures (one ARM, the other MIPS). Its "dual dedicated CPUs" must be each running a separate operating system.
23-09-2014 2:40 PM
ASUSWRT DSL-AC68U_3.0.0.4 Mon Aug 25 03:53:12 UTC 2014
admin@DSL-AC68U:/tmp/home/root#
3ginfo.sh du lsmod setconsole
ATE e2fsck lsusb setup_dnsmq
[ eapd madwimax setuprsa.sh
[[ ebtables md5sum sh
acsd echo mdev sigmon
ad egrep memalloc sleep
add_account ejusb minidlna smbd
add_folder email miniupnpd smbpasswd
add_multi_routes emf mkdir sort
adslate env mke2fs spectrum
afpd epi_ttcp mkfs.ext2 strings
afppasswd et mkfs.ext3 swapoff
app_base_library.sh ether-wake mkhfs swapon
app_base_link.sh expr mknod switchmode
app_base_packages.sh ez-ipupdate mkntfs sync
app_cancel.sh fdisk mkswap sysinfo
app_check_folder.sh fgrep mod_account syslogd
app_check_pool.sh find mod_folder tail
app_fsck.sh find_modem_node.sh modem_enable.sh tar
app_fsck_all.sh find_modem_type.sh modem_signal.sh taskset
app_get_field.sh firmware_check modify_if_exist_new_folder tc
app_init_run.sh flock modprobe tcpcheck
app_install.sh free more telnet
app_move_to_pool.sh free_caches mount telnetd
app_remove.sh fsck.ext2 mt-daapd test
app_set_enabled.sh fsck.ext3 mtd-erase2 test_disk1
app_stop.sh fsck.minix mtd-unlock test_disk2
app_switch.sh fsync mtd-write2 test_endian
app_update.sh ftpget mv test_if_exist_account
app_upgrade.sh ftpput nas test_if_exist_share
arp gctwimax netstat test_of_var_files
arpstorm gencert.sh netstat-nat test_share
ash get_account_list networkmap test_system
asus_lp get_all_folder nice tftp
asus_sd get_apps_name nmbd top
asus_sg get_folder_list nohup touch
asus_sr get_permission nslookup tp_init
asus_tty get_phy_speed ntp tr
asus_usb_interface get_phy_status ntpclient traceroute
asus_usbbcm get_var_file_name nvram traceroute6
asuswebstorage gpio nvram_erase true
auto_det grep openssl tune2fs
auto_macclone gunzip openvpn u2ec
autodet gzip ots udevtrigger
avahi-daemon halt pc udhcpc
awk head pidof udpxy
basename hotplug ping umount
bcrelay hotplug2 ping6 uname
blkid how_many_layer pppd uniconv
brctl httpd pppoe-relay unzip
busybox hub-ctrl pptpctrl updown.sh
cat icon.ico pptpd uptime
chat icon.large.ico preinit uqmi
check_spectrum.sh ifconfig printf usb_modeswitch
chk_app_state igmpproxy ps usb_notify
chkhfs igs psta_monitor usbled
chkntfs infosvr public.pem usbtest.sh
chmod initial_all_var_file push_log usleep
chown initial_folder_list pwd vconfig
chpasswd initial_var_file radio vi
chpasswd.sh inotify radvd vsftpd
clear insmod rc wanduck
cmp ionice rcheck watch
cnid_dbd ip rdnssd watchdog
cnid_metad ip6tables read_sms wc
comgt ip6tables-restore readlink webs_update.sh
console iptables reboot webs_upgrade.sh
cp iptables-restore renice wget
create_if_no_var_files iptables-save req_dsl_drv which
crond kill restart_wireless wimaxc
cru killall rm wimaxd
cut klogd rmdir wl
date l2tp-control rmmod wlcconnect
dbd l2tpd route wlconf
dd led_ctrl rsasign_check wlcscan
ddns_updated less rstats wpa_cli
del_account lighttpd run_app_script wpa_supplicant
del_folder lighttpd-arpping run_pptpd wps_monitor
df lighttpd-monitor run_telnetd wpsaide
dhcp6c lld2d scsi-start write_3g_ppp_conf
dhcp6s lld2d.conf scsi-stop write_smb_conf
dirname ln sdparm write_webdav_conf
disk_monitor logger sed xtables-multi
disk_remove login send_sms zcat
dmesg lpd service zcip
dnsmasq ls set_permission
23-09-2014 2:53 PM
cat /proc/cpuinfo
That will tell you the chipset. I'm pretty sure Asus use Ralink/MediaTek for their modem routers.
23-09-2014 2:56 PM
23-09-2014 2:59 PM
23-09-2014 3:04 PM
admin@DSL-AC68U:/tmp/home/root# cat /proc/cpuinfo
Processor : ARMv7 Processor rev 0 (v7l)
processor : 0
BogoMIPS : 1599.07
processor : 1
BogoMIPS : 1599.07
Features : swp half thumb fastmult edsp
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
Hardware : Northstar Prototype
Revision : 0000
Serial : 0000000000000000
how can i pull my line stats. adslphxcmd info --show does not work
23-09-2014 3:09 PM
DSL-AC68U uses a MediaTek chipset for its DSL, this has lineage back to the Trendchip chipsets. Trendchips have a bad rep for poor reliability especially on bad and/or long lines. I would recommend to return the DSL-AC68U as not fit for purpose and use a modem/router in bridge mode and the ASUS RT-AC68U wireless router instead?
23-09-2014 3:40 PM
23-09-2014 6:43 PM
Once you're in telnet in the WiFi router part, you'll need to telnet again to get into the modem, but of course you'll need to work out it's IP address. Try:
cat /proc/net/arp
That should show the IP addresses of all connected devices. You'll have to work out which one is the modem, it'll be one you don't recognise. Then telnet to that IP, and then if you do "cat /proc/cpuinfo", it'll be totally different. Then you'll be able to access the modem stats.
