ADSL2+
andun84
ADSL2+
I was checking out my sister's line on the bt adsl checker and it says:
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 8Mbps; typically the line speed would range between 7Mbps and 8Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 17Mbps; typically the line speed would range between 10Mbps and 19.5Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1.5Mbps and downstream line speed of 17Mbps; typically the downstream speed would range between 10Mbps and 19.5Mbps.
When I look in her high speed broadband in the member centre I note she is getting 6.5mb so I'm assuming she is on ADSL max. How does she go about getting ADSL2+ on her line?
12 REPLIES 12
Fixes: 62
Re: ADSL2+
Assuming this says 21CN is available then just raise a ticket on her account but make sure that the router supports ADSL2+
http://usertools.plus.net/exchanges/
andun84
Re: ADSL2+
Looks like she is out of luck then as it says:
BT have advised that no current planned date for WBC on 21CN exists
Oh well fibre is coming in the next few months (unless it slips a bit) if she wants that.
richandsian
Re: ADSL2+
Quote from: Oldjim
Is this up to date?
For instance, with the Broadway exchange it seems to disagree with the information here:
http://www.samknows.com/broadband/exchange_search
Fixes: 103
Re: ADSL2+
Surely, if the BT Wholesale checker says this
then 21CN must already be available.
Fixes: 62
Re: ADSL2+
andun84
Re: ADSL2+
Mmmm that suggests that 21CN is enabled:
ADSL status:
Enabled as of 12/11/2003
ADSL Max status:
Enabled as of 31/03/2006
SDSL status:
Not available
21CN WBC status:
Enabled
FTTC status:
Available in some areas
Fixes: 62
Re: ADSL2+
In which case raise a ticket - they can only say "The computer says no"  Grin
andun84
Re: ADSL2+
Too true. Thanks
x47c
Re: ADSL2+
Just a note to say that it is possible in some circumstances to have FTTC at your local cabinets and not have 21CN/ADSL2+ at the local exchange.
FTTC runs over the 21CN network BUT the FTTC supply does not HAVE to come from the same local exchange as the phone/ADSL comes from.
The FTTC supply might come from a nearby larger exchange which is fully FTTC/21CN enabled.
Pettitto
Fixes: 5
Re: ADSL2+
Hi andun84,
I'm glad we managed to get that all sorted. That should all be sorted within 7-10 working days. Let me know if there is anything else I can help with Smiley
andun84
Re: ADSL2+
Thanks Chris for picking this up and getting the adsl2+ product put through. It's much appreciated.
Fixes: 113
Re: ADSL2+
I'll pass your thanks on to Chris, cheers for letting us know.
 Adam Walker
