ADSL2+ ?
- ADSL2+ ?
Re: ADSL2+ ?
22-12-2013 10:25 PM
Will see what they say and report back..
Re: ADSL2+ ?
22-12-2013 10:41 PM
All done ..one phone call....Great !!
Will all be done by end of December !!
Re: ADSL2+ ?
23-12-2013 9:53 AM
Re: ADSL2+ ?
23-12-2013 11:50 AM
Ex-Broadband Service Manager
Re: ADSL2+ ?
24-12-2013 8:44 PM
I understand xmas is here , but before New Year would be great, just a txt or email would be fab...Cheers....
Leighton
Re: ADSL2+ ?
24-12-2013 11:41 PM
Your router will then have to re-sync and if you check your router stats you should see a DSL Type/Connection Mode of ITU-T G.992.5 (or -3) instead of ITU-T G.992.1 (the last digit changes). Hopefully also a higher sync speed.
Re: ADSL2+ ?
25-12-2013 7:27 PM
Just checked and nothing has been done yet , as expected....
Link Information
Uptime: 2 days, 5:37:59
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8.128
Data Transferred (Sent/Received) [MB/GB]: 697,30 / 1,99
Once again...thanks for answering ,and showing how clever you are, and how dumb I am !!!
Looking forward to a little speed boost !!
Cheers
Leighton
dick:quote
Re: ADSL2+ ?
25-12-2013 8:28 PM
Don't worry about not knowing things, we all learn by asking. You are doing fine providing useful information that helps others to provide (hopefully helpful) responses.
David
Re: ADSL2+ ?
25-12-2013 8:56 PM
Can't find the downstream attenuation stats anywhere ?
Re: ADSL2+ ?
25-12-2013 9:09 PM
Data Transferred (Sent/Received) [MB/MB]: 836,73 / 579,00
Output Power (Up/Down) [dBm]: 12,3 / 20,0
Line Attenuation (Up/Down) [dB]: 18,0 / 32,5
SN Margin (Up/Down) [dB]: 29,0 / 6,5
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 160 / -
FEC Errors (Up/Down): 127 / 0
CRC Errors (Up/Down): 0 / 234
HEC Errors (Up/Down): - / 234 / 456
There..It makes no sense to me..probably will to you guys though....
Cheers..
Re: ADSL2+ ?
26-12-2013 6:59 PM
Don't know what attenuation is ? and if my figures are good or bad ?
Cheers
Leighton
Re: ADSL2+ ?
26-12-2013 8:41 PM
Quote from: beaky32 Line Attenuation (Up/Down) [dB]: 18,0 / 32,5
The line I've highlighted in red gives the attenuation with SN Margin (another important parameter) below it.
Using the Kitz calculator for that attenuation I'd expect your downstream sync speed/bandwidth to increase to about 13000kbps on ADSL2+. So a decent improvement.
Since the Chipset Vendor ID (Remote) in those stats shows as IFTN it looks to me that you could already be on 21CN but with an ADSL1 service. Perhaps the hardware move has already completed, just awaiting BT and Plusnet to make administrative changes to your account. If the automated systems don't follow this through, hopefully Plusnet DCT staff will follow it up on Friday.
David
Re: ADSL2+ ?
26-12-2013 9:10 PM
13 meg would be fantastic !!...
Just had an email from Plusnet saying my changes would be completed on the 6th Jan....
That will be fantastic !!
Once again thanks for all your help !!
Regards
Leighton
Re: ADSL2+ ?
27-12-2013 10:38 AM
Are these Conservative estimates ?
Re: ADSL2+ ?
27-12-2013 12:30 PM
It would also be useful to check present speeds using the BT Performance Tester. Just make sure nothing else is running, don't restart the router or your PC, nor turn off antivirus or how you connect to the router. Is that wired (preferable) or wireless?
After running the initial test, click the further diagnostics button at the bottom of the page then enter your phone number. The 3 or 4 lines in the framed boxes are the useful bits.
David
