ADSL2?? when and how??
- ADSL2?? when and how??
01-06-2010 10:08 PM
My exchange has had ADSL2 for ages now and Im still on original ADSL. I joined in September and then for some reason I got an email in November saying my order was being progressed. Unfortunately it didnt give details on what order was progressing!!! I was wondering if that was when I was maybe supposed to get switched over.
Although looking at all the forum chat regarding ADSL2 I dont know if its a good idea!! Hehe!! Anyway some info would be good.
Cheers.
Re: ADSL2?? when and how??
01-06-2010 10:16 PM
01-06-2010 11:26 PM
02-06-2010 12:17 AM
So I suggest you raise a ticket and first ask if you are on the 21CN network. If you are then ask to be changed to ADSL2+, and while you are at it get the upload limit removed.
02-06-2010 3:05 PM
SQUEAK.
Also, I've placed your modify order to move you to the up to 20Mb service which is due to complete tomorrow. That's also with an uncapped upstream.
Hope that helps,
02-06-2010 6:47 PM
Is there anything I need to do my end when this change happens? Are there any settings I need to change or will it be automatic?
03-06-2010 10:59 AM
03-06-2010 9:56 PM
03-06-2010 10:56 PM
I hate to tell you this, just cause you are in essence only a few hundred metres away from the exchange doesn't mean your line will be this length.
As the crow flies, I am 1.1km away from my exchange, but my actual line length is around 2.6km meaning I get around 13mb at the moment, and that is with a current fault with current copper lines in place.
Give it time, as when you move to ADSL2+ on the 21CN side of things, you go through a whole new 10 day training period as you did when you were put onto ADSL Max...
Hope this clears things up a abit.
CB
04-06-2010 12:05 AM
04-06-2010 8:50 AM
04-06-2010 10:12 AM
Edit: If you put the downstream attenuation reported by your router in to http://www.kitz.co.uk/adsl/max_speed_calc.php you will get a good estimate of your actual line length and the speed you can expect.
04-06-2010 9:18 PM
System Up Time 05:27:19
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 76132 81825 0 564 5004 05:26:22
LAN 10M/100M 51639 50918 0 3455 433 05:27:15
WLAN 11M/54M 33861 27901 0 1646 220 05:27:05
ADSL Link Downstream Upstream
Connection Speed 10231 kbps 834 kbps
Line Attenuation 14 db 3 db
Noise Margin 15 db 11 db
The Kitz checker reckons my profile should be 19000!!!
04-06-2010 9:53 PM
Leave your router permanently on and reboot once a day only between 10am and 3pm, then keep an eye on your up time to make sure you are not get disconnects between. It will take a little while but you should see BT reduce your target noise margin which will give you better speeds.
04-06-2010 10:02 PM
