ADSL2+ performance deteriorates over the day
- ADSL2+ performance deteriorates over the day
02-04-2009 11:30 PM
Hi all,
I've been on the trial now for about a month and have increasingly noticed that over the course of 24 hours my download speed decays. On an evening I can have between 10-12 Mbps (based on a My Broadband Speed test) however by the following evening this can be down to > 0.5 Mbps. The upload speed remains constant at about 371Kbps. My router reports a decent down sync rate around 15Mbps and an up of 448Kbps whatever the speed test shows. This problem is immediately corrected by rebooting the modem (Netgear DG834G v2 firmware 3.01.38) after which my speed is back up at the 10-12 Mbps that would be suggested by the down sync rate.
Initially I put this down to the modem training but it's been going on long after the 7-10 days I would have expected. I can't be sure if this happens slowly or over a short period as I only notice it either end of the day. I've included a shot from the router stats below. Any ideas what the cause is or better still the cure?
Cheers,
-Toenex
ADSL Link | Downstream | Upstream |
Connection Speed | 12678 kbps | 448 kbps |
Line Attenuation | 23 db | 7 db |
Noise Margin | 9 db | 25 db |
Cheers,
-Toenex
Message 1 of 4
(1,041 Views)
3 REPLIES 3
Re: ADSL2+ performance deteriorates over the day
02-04-2009 11:41 PM
Not related to your deteriorating download speed but I can see that you have been incorrectly provisioned with a capped upload speed - you should be getting over 1mbps.
You need to send a PM to PM Jameseh.
See http://community.plus.net/forum/index.php/topic,75080.0.html
Message 2 of 4
(373 Views)
02-04-2009 11:44 PM
Thanks for that, done.
-Toenex
-Toenex
Message 3 of 4
(373 Views)
03-04-2009 12:24 AM
With 23dB you should be around 19mbps.
What performance do you get from the BT Test Socket?
Message 4 of 4
(373 Views)
