ADSL2+ awful gaming
chesterfield
ADSL2+ awful gaming
Well, ever since moving to ADSL2+ a few weeks ago Ive suffered problems with online gaming (xbox).  Previously had a great connection with very low ping and no issues in voice chat.
Now, I get double the pings I had before, and my voice keeps cutting out internittently online.  I can hear everyone else fine, but mine keeps cutting out - so im pointing the finger at upload issues.
Anyone else experienced this?
Have now tried three different routers, xbox is wired directly to router.  Though as the only thing that has changed is moving to ADSL2+, then Im assuming this has caused the issue rather than anything internally.  Im guessing that having interleaving turned on wont be helping, but IM getting bored of turning this off in the PN control panel - seems it doesnt raise the request anymore, as there is no ticket raised to turn interleaving off whenever I click it.
I wonder if my profile at PN has been altered at all, as it appears to be a poor gaming connection compared to what Ive experienced in the past.
23 REPLIES 23
Kelly
Fixes: 9
Re: ADSL2+ awful gaming
We'll have a good look tomorrow!
Kelly Dorset
Ex-Broadband Service Manager
Gus
The interleaving button is a ghost button, it shouldn't be there.  Also reported it didn't work and was told it should have been removed automatically but wasn't.  Its a left over from a legacy account type.
As for your gaming issues can't comment, pc only gamer.  But interleaving will add a fair amount to your basic pings.  Currently don't have it enabled and get 25ms outside of any game, it would be 45-50 nonce in game for a uk hosted server and 100-120 in USA.  But with interleaving on, that adds a further 25-30ms on top.
So if your connection is stable make sure that its set to Off and not automatic, or it gets turned back on.
FTTP 500 regrade from Tues 28th November
chesterfield
Interestingly, Ive seen a fair few disconnections tonight, normally a very solid connection, but tonight I must have had half a dozen or more disconnects in the space of an hour.  No real issue with SNR as its still synchronizing at 3 db SNR. 15000+ rate.  Perhaps there is a service issue in our area, as Ive never noticed it do that before.
Kelly
Fixes: 9
Lots of disconnections!
Something wrong there!
Kelly Dorset
Chris
Legend
Fixes: 169
That is quite a lot of disconnections in a short time. I'm assuming you're in the master socket?
Once the disconnections have stopped, we'll be happy to turn interleaving off from here for you.
chesterfield
Yep, the disconnections started last night, and as you can see they were about 2-3 minutues apart at times.  Then this morning they went to being less frequent.
I had an engineer visit a short while ago due to issues with the broadband and he put the line straight to a new ADSL specific plate, with just one single pair then isolated and sent to one phone socket (that has a filter).  He checked the line afterward and advised no errors what so ever.
Ive been synchronising at 12000, and its worked its way up to 15000.  During the disconnects last night there was no attempt to raise the SNR, so I can only assume that it was a problem exchange end.
The disconnection on Monday (12th) was me, as I was uncertain as to why wireless performance was not working correctly on one machine, turned out to be a channel issue, but I restarted as thought it may have been a gateway issue at PN.
The disconnects last night were ridiculous, and certainly nothing at my end.
Any chance of having a look and seeing what the connection has been throughout the day?  Im keen to get interleaving off, and see if it sorts out this awful upstream error that I think is causing my communications online to suffer.
chesterfield
Fine all evening, until another random drop of ADSL at about 9.40pm.....  Roll_eyes
EDIT - after another drop about 10 minutes later, I decided to swap from my brand new DGN2200 back to my old Belkin.  So far no drops since.  Still rubbish voice chat online (upstream voice broken, downstream fine), but no disconnects.
Seems my new Netgear was a pointless purchase.
chesterfield
Unfortunately the logs are a bit pants on the Belkin - can any helpful PN soul see if my connection has been stable since I swapped my router over around 11pm?
Kelly
Fixes: 9
Latest connection was at 21:55 14/Nov/2012
Kelly Dorset
chesterfield
Seems I must have swapped the router over at 10pm ish then.  I seem to remember reading somewhere about the netgear dropping adsl quite often.  Hmmm.  Ill send it back and stick with the belkin.
Any ideas what could be causing the issue with voice chat?  The only thing that has changed (and it changed at around the same time as the errors started) is moving to 21CN.  Prior to that I didnt have a problem online.  Good pings, no break up in voice.  Now, although I have a much faster download speed, (and upload), the quality of the connection in terms of pings seems quite poor, and Im assuming as I can hear everyone else just fine, and its my voice that breaks up etc - its an issue on the upstream.
Could this be fixed by the removal of interleaving?  How long should I expect the connection to be stable for before BT/PN will request interleaving turned off?
Kelly
Fixes: 9
Could be something swamping your upstream connection, or a fault of some sort.
Someone needs to run a check on your line.    Adam will sort I expect Cheesy
Kelly Dorset
chesterfield
There are no other devices online at the time that Im using the xbox.  I can certainly try isolating all other equipment by turning off the wireless and removing all cables but the one for the xbox from the router.
The connection itself, other than the disconnects on Tuesday has been fine.  Its just this intermittent drop out of voice that is becoming an annoyance.  Ive tried a different xbox, different headsets, wired/wireless controllers, different routers, going direct to the router rather than through the switch etc...  All have had no effect, and the problems started after I switched to 21cn, or after the engineer visit to fix my line when I had the adsl specific socket fitted.  They were within a few days of each ither iirc so could have been either one of those.
Can PN check that im provisioned on the right profile after the move to 21cn?  Im wondering if Ive made it onto a profile where gaming traffic is managed at certain times?  Just trying to think of anything that could be the issue really.
Thanks for your help Smiley  Im sure the issue will be found at some point.  Ill just have to put up with people thinking Im talking in riddle, and being shot more often than I should on Black Ops for a while until we find it  Grin
adamwalker
Fixes: 221
Re the disconnections it's looking good so far today but we'd want to see at least 72 hours of stability before we could look at turning interleaving off for you:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image1352991299960.png" />
I've just performed a diagnostic test and BT's IP profile is 12500kbps at the moment and our systems are matching that. In terms of a traffic management profile that's also set to the correct one for the pro add-on that you have.
In my opinion I think we should see how things play out over the next 24-48 hours and see if the connection remains stable. If it does then remove interleaving and see if that has a positive effect on your experience. If the connection is no more stable we could then take a look at it from a faults perspective and deal with that issue for you.
Adam
 Adam Walker
chesterfield
Sorry to bump this again - has my connection been stable over the last few days?  Cant see any signs of disconnects in the logs, but they aren't the greatest on this router.  Wonder if its worth trying to get interleaving switched off again now?
