ADSL2+ Slower than ADSL MAX
Extremedel
Re: ADSL2+ Slower than ADSL MAX
No, but I will ask !
scootie
follow this to get the stats from your router http://www.kitz.co.uk/adsl/frogstats.php
Extremedel
it is a Linksys WAG54G2 and I can not see where to get that info ?
Fixes: 71
Assuming it is similar to the Linksys WAG54GS, to get router stats try the following (based on information from Kitz frogstats page):
Enable debug by clicking the link or entering http://192.168.1.1/setup.cgi?todo=debug in your browser address bar
Open a command prompt window (Start->Run then type cmd and click OK with Windows XP)
Telnet into the router by typing telnet 192.168.1.1 and pressing enter
Type adslctl info --stats and press enter
Type exit and press enter to end the telnet session
David
scootie
if the 2 is meaning V2 then these are the instructions from the kitz page
v2 of this router.
From the web interface http://192.168.1.1
> Status
> DSL Connection
Default username and password are "admin".
didnt notice the reply 12 test results.
reply 2. 23rd
Downstream Link Info
  Loop Loss 49.8
  Loop Loss Add Text N/A
  SNR Margin 18
  DSL Max Data
  BIP Interface Data
  Current line rate 2500
  Line rate change timestamp 16/03/2009 00:00:00
  Maximum Stable Rate Recalcuated N
  ProfileTimestamp 01/01/1111 00:00:00
  Maximum Stable Rate 2272
  Fault Threshold Rate 2272
  Interleaving Flag A
reply 12. 28th
Loop Loss 50
SNR Margin 9
DSL Max Data
BIP Interface Data
Current line rate 4000
Line rate change timestamp 25/03/2009 18:38:05
Interleaving Flag A
Downstream Rate: 5234 kbps
Upstream Rate: 444 kbps
it seems your downstream snr lowered before the upstream cap was removed.
did you make any changes to your wiring setup in this time or has it just stablised on its own?
James
Downstream attenuation is 50dB if you're still interested.
