ADSL2+ Slower than ADSL MAX
- Re: ADSL2+ Slower than ADSL MAX
23-03-2009 8:04 PM
Derek
23-03-2009 9:12 PM
23-03-2009 9:21 PM
Mux Port Status N/A
Upstream Link Info
Loop Loss 24.3
Loop Loss Add Text N/A
SNR Margin 22.5
Errored Seconds 0
HecErrors 0
Cell Count 37259
Speed 443
Downstream Link Info
Loop Loss 49.8
SNR Margin 18
Errored Seconds 0
HecErrors N/A
Cell Count 769560
Speed 3071
DSL Max Data
BIP Interface Data
Current line rate 2500
Line rate change timestamp 16/03/2009 00:00:00
Maximum Stable Rate Recalcuated N
ProfileTimestamp 01/01/1111 00:00:00
Maximum Stable Rate 2272
Fault Threshold Rate 2272
Interleaving Flag A
I think this with pic is all that you want ?
Derek
23-03-2009 10:06 PM
iam more after what your current stats from your router are than test results PN have run.
as for you upsync not improving please read this thread http://community.plus.net/forum/index.php/topic,75080.0.html
i note your downstream loop loss/attention is 49db on pn test run.
do you know at all if this was the same when you where on adsl? i cant see it being the same as you say you where geting 6mb on adsl
iam on 51db atten line and on adsl i get max daytime sync of 4000kbps and average ip profile of 3000kbps
23-03-2009 10:36 PM
444UP
23-03-2009 11:24 PM
Loop Loss 49.8
SNR Margin 18
the lowest target snr on adsl2+ is 6db or 3db so having a snr of what i think would be a target of 15(but at the mo on adsl2+ anything seems posable and maybe target of 18db) means the exchange is seeing your line as unstable and trying to stablise it by uping the SNR resulting in a lower sync.
but the main 2 things concerning me here is the fact you said you got 6mb on adsl which would mean alot lower attention/loop loss than 49db
and the fact you have seein no increase in up sync speed which i belive you need to pm jameseh to sort out as per the info in the thread link i gave before about orders being placed on capped upstream.
i think you should get jameseh to sort the upsteam out and see what line stats you have after that before investigating more as downstream might sort it's self out once jameseh has put a new order in to BTw to sort upstream problem
24-03-2009 7:50 PM
25-03-2009 8:53 PM
Dear Mr Atkinson, Thank you for your response, 444k is a perfectly normal upload speed, bear in mind that the A in ADSL stands for Asynchronous (but is also referred to as asymmetrical), and this means the downstream speeds should always be significantly higher than the upload.
25-03-2009 9:01 PM
you need to pm jameseh as he's dealing with these's re orders. click his name a title it somthing like adsl2+ capped upstream and ask him to place a modifyed order for you.
25-03-2009 9:08 PM
Derek
25-03-2009 9:10 PM
things like the attention/loop loss, snr/noise margin, sync rates
thanks
25-03-2009 9:18 PM
28-03-2009 9:40 PM
Circuit Sync Status Circuit In Sync
Mux Port Status N/A
Upstream Link Info
Loop Loss 24.3
SNR Margin 22.5
Errored Seconds 0
HecErrors 0
Cell Count 8692
Speed 443
Loop Loss 50
SNR Margin 9
Errored Seconds 20
HecErrors N/A
Cell Count 6890
Speed 6264
DSL Max Data
BIP Interface Data
Current line rate 4000
Line rate change timestamp 25/03/2009 18:38:05
Interleaving Flag A
NTE Detail
Equipment Status N/A
Power Status NTE Power On
BypassStatus N/A
Outcome Summary
Test OutCome Pass
Description OK.
Status: Up
Downstream Rate: 5234 kbps
Upstream Rate: 444 kbps
PVC Connection
Encapsulation: RFC 2364 PPPoA
Multiplexing: VC
QoS: UBR
PCR:
SCR:
Autodetect: Enable
VPI: 0
VCI: 38
Enable: 1
PVC Status: Up
Upstream order will be sorted on monday I am now told, will let you know result.
Derek
30-03-2009 7:34 PM
Status: Up
Downstream Rate: 5791 kbps
Upstream Rate: 891 kbps
PVC Connection
Multiplexing: VC
QoS: UBR
PCR:
SCR:
Autodetect: Enable
VPI: 0
VCI: 38
Enable: 1
PVC Status: Up
30-03-2009 7:57 PM
any idea what attention/loop lose and snr/noise margin is being reported as now ?
