ADSL2+ Rejected by BT
- ADSL2+ Rejected by BT
03-08-2011 4:10 PM
I want to go onto BT ADSL2+ because I been on ADSL up to 8Mbps far too long now.
Re: ADSL2+ Rejected by BT
03-08-2011 4:19 PM
I'll have a look now and see if I can find out why.
Jojo
03-08-2011 4:22 PM
03-08-2011 4:35 PM
I've placed the order manually. It takes 7 days to complete and I've emailed you confirmation.
Jojo
03-08-2011 4:44 PM
03-08-2011 4:46 PM
03-08-2011 4:47 PM
03-08-2011 4:58 PM
03-08-2011 5:20 PM
Is there a particular reason why the automated order failed though? (Problem with BTs system if its a recently upgraded exchange?)
Quote few minute later
Would it be worth agents, who set automated orders through have them checked at the end of their shift, for example? (just to ensure none have failed & to put them through manually) - seems doing it manually is adding an un-needed delay and issue
Regards
04-08-2011 9:50 AM
I think it was a rookie agent error possibly. There are many other reasons why orders get rejected though, and I'm not sure if it would be viable for us to wait and see if every order we place gets rejected. Most orders go through fine, and the manual ordering process is quite long winded and time consuming. I think the way it works now is the best. If an order is rejected a ticket drops onto the account and an agent can work that ticket.
Jojo
04-08-2011 1:54 PM
04-08-2011 4:07 PM
It always takes 7 days for this kind of order, because it's being moved from a different technology. I suspect the confusion about 24 hours came from moving from ADSL1 to ADSL2+ on 21CN which takes 24 hours, but moving from 20CN to 21CN takes 7 days. As far a retraining goes, it is very similar, although they sometimes use something called modified FTR, where they carry across the FTR (Fault Threshold Rate) and MSR (Maximum Stable Rate).
Jojo
04-08-2011 6:07 PM
Ah, fair enough with more clearly explaining. Many thanks jo. Hope BT will do FTTC next stage at my exchange next year who know (?)
Best Regards
Goldenadsl
05-08-2011 11:55 AM
05-08-2011 12:30 PM
Quote BT will put my line back on interleaving on or will remain staying at Fast Path ?
Should remain the same, interleaving will only be applied if the line becomes unstable (for whatever reason)
Regards
