ADSL2+ Hardware effects possibly
- ADSL2+ Hardware effects possibly
12-11-2009 1:46 PM
http://forums.thinkbroadband.com/btsupplier/t/3740093-re-do-btw-treat-dslam-information-as-confident...
Quote On Huawei there was signs of compatibility issues from the TalkTalk roll-out, so face of no surprise is showing.
But someone probably got a good deal.
I've got some data that shows on ADSL2+ on the same line the choice of hardware makes a big difference, and price is not the factor, we need to write that up at some point.
Andrew Ferguson, andrew@thinkbroadband.com
Message 1 of 4
(1,597 Views)
3 REPLIES 3
Re: ADSL2+ Hardware effects possibly
12-11-2009 9:38 PM
I'm sure we've asked them about that, but will have to check up...
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 2 of 4
(452 Views)
13-11-2009 5:44 PM
http://apcmag.com/optus_admits_broadband_network_problem.htm
Quote Optus has admitted the Huawei hardware running its ADSL2+ broadband network "does not support" certain brands of modem.
Worse, if a user tries to connect with one of the modems, it will lock up the user's port at the exchange, requiring a manual reset by Optus technical staff.
Message 3 of 4
(452 Views)
Re:ADSL2+ Hardware effects possibly
16-11-2009 9:51 AM
I know we've been asking questions as Dave says, but isn't Optus an Australian ISP?
Either way I'll give Dave a nudge and see where we got to.
Message 4 of 4
(452 Views)
