ADSL with a MK2 BT faceplate
chenks76
All Star
Fixes: 12
if a house has a MK2 BT faceplate but has ADSL rather than fibre, and has extensions running from the master MK2 socket (wired internally to the master socket), are those extensions pre-filtered?
reason i am asking, a house has this setup, but wants to have the ADSL router connected to a different socket in the house.
3 REPLIES 3
Fixes: 160
Re: ADSL with a MK2 BT faceplate
Yes, the extensions will be pre-filtered.
You would have to move the extension wiring onto the AB terminals and use filters everywhere.
chenks76
All Star
Fixes: 12
and can they wired to the AB terminals by joe public? (ie i mean are you allowed to do that).
Fixes: 160
To the AB terminals on the VDSL face plate yes, on the back plate no.
