ADSL wireless router
- ADSL wireless router
Re: ADSL wireless router
30-11-2015 10:49 AM
Don't forget that you will also find the detailed information for setting up HH's for both FTTC and ADSL in this thread mentioned in replies #1 & #5 as well as some useful comment there.
30-11-2015 11:00 AM
1. Can I set it up off line with my lap top as I was able to do with Netgear DGND3300 dual band? YES
2. Do I need to key in Bt supplied password to access the configuration page? YES the one on the card at the back of the unit.
3. Is it possible to set up MY SSID and Pass Key for wireless (so I do not need to reconfigure password my other wi-fi devices) ? YES
Just a quick note on setting up, as long as you have an account that ends in @plusdsl.net, otherwise the unit can only be used as an access point in conjuction with your current router/ modem.
Benefits noted by myself is Gigabit networking and also extended/ quicker wireless connectivity.
Just need to look for a 802.11ac usb adapter for my laptop now to isolate myself from the crowded neighbourhood 2.4GHz band
Albert Einstein
30-11-2015 8:54 PM
Quote from: Anotherone @chandu
Thanks, Anotherone. It's appreciated.
chandu.
30-11-2015 8:56 PM
Thanks, that is re-assuring. Yes, I do have a @plusdsl.net account.
Much appreciated.
Chandu.
30-11-2015 9:00 PM
Quote from: MatrixRob @Chandu
Not clear what it means in real terms. Please elaborate on this, please.
Chandu.
30-11-2015 9:40 PM
I'm a bit confused as to why you have opted for a BT HH5 when you already had a Netgear DGND3300, have you had problems with it?
Albert Einstein
01-12-2015 5:48 PM
I believe, it has some issues. Lately kept dropping PPPoA very frequently and hence speed suffered under DLM.
Currently, I have plugged-in my 8-yr old NetgearDG834GT, but find the wireless signal is weaker. The reason I need the stronger faster wireless signal is that my master socket is in the entrance hall (where my router resides) and I do not have much space there.
Hope above clarifies my situation. Thanks for your help.
Chandu.
03-12-2015 2:54 PM
Just a quickie on BT HH5. Does anyone know the differences between HH5A and HH5B? I tried to Google for it but did not get anywhere. So, will appreciate your help.
Thanks in advance.
Chandu.
03-12-2015 3:32 PM
The HomeHub 5 is an all in one VDSL modem/router supplied to new BT Infinity customers. It can be distinguished by its blue stripe from the HomeHub 4. A little know fact is there are two versions of the HomeHub 5. They look identical but can be identified by the firmware it uses.
•HomeHub 5A - This contains a Lantiq VRX-268 chipset and is currently NOT fully G.INP compatible.
(Software version 4.7.5.1.83.8.204)
•HomeHub 5B - This is manufactured by Arcadyan and contains a BCM 63168 chipset and is G.INP compatible.
(Software version V0.07.01.0235-BT)
03-12-2015 6:40 PM
Albert Einstein
03-12-2015 8:22 PM
So whether what's been quoted for the type A is correct or not, maybe someone could check.
03-12-2015 9:15 PM
Albert Einstein
05-12-2015 11:04 PM
The Plusnet Hub One (based on the type A but at least with a new skin) is Software version 4.7.5.1.83.8.217 Last updated Unknown.
06-12-2015 12:00 AM
I have followed the procedure on this thread regarding using HH5 for Plusnet; but failed miserably. I have recently purchased New HH5A from eBay.
I am unable to connect to plus net and Advance Settings, Broadband, Internet gives the following:
Connection Time: Disconnected,
My username and Password,
TCP/IP settings are:
Broadband Network IP address: Not applicable,
Default Gateway: Not Applicable,
Primary DNS: Not Applicable,
Secondary DNS: Not Applicable.
1) Where do I enter the above TCP/IP Info.? I have perused through various tabs Under Settings & Advanced Settings, but no joy.
2) For ADSL, Plusnet has Network Type: PPPoA and wants the Encapsulation for Modems to be set for PPPoA. So, how do I set this for Plusnet ADSL2 use? Or does it automatically detect this & set it up?
I will appreciate help from all quarters. The Plusnet support personnel conversant with HH5A may be able to throw some light in getting me going.
Thanks in advance, Guys.
Chandu.
06-12-2015 4:56 AM
What information did you get when you looked at >Advanced Settings >Broadband >Connection - was it showing Line State Connected, and Downstream and Upstream speeds?
If when you looked at >Advanced Settings >Broadband >Internet was it showing your Broadband username correctly? And hopefully it wasn't showing the password as not configured. The Broadband username should be the full myusername@plusdsl.net and the password is case sensitive.
