ADSL to ADSL2+
- ADSL to ADSL2+
ADSL to ADSL2+
10-01-2013 9:26 AM
I am within 200m of the exchange.
My line stats when on 20CN Downstream margin 5db syncing at 8128kbs since 2006
On 2/1/13
DSL Status: Connected
DSL Modulation Mode: MultiMode
DSL Path Mode: Interleaved
Downstream Rate: 20626 kbps
Upstream Rate: 1091 kbps
Downstream Margin: 6 db
Upstream Margin: 7 db
Downstream Line Attenuation: 7 db
Upstream Line Attenuation: 0.5 db
Downstream Transmit Power: 9 db
Upstream Transmit Power: 13 db
07/01/13¬
Downstream Rate: 21216 kbps
Upstream Rate: 1063 kbps
Downstream Margin: 1 db
Downstream Line Attenuation: 5 db
Upstream Transmit Power: 12 db
10/01/13 9:17
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB023k.d21d
DSL VPI/VCI: 0/38
DSL Status: Showtime
DSL Mode: ADSL2+
DSL Channel:
DSL Upstream Rate: 1119 Kbps
DSL Downstream Rate: 6656 Kbps
Down up
DSL Noise Margin: 30.3 dB 6.5 dB
DSL Attenuation: 8.0 dB 2.0 dB
DSL Transmit Power: 0.0 dBm 11.0 dBm
How do I get back to the good connection?
Re: ADSL to ADSL2+
10-01-2013 9:31 AM
Re: ADSL to ADSL2+
10-01-2013 2:43 PM
Quote from: zpeterk DSL Downstream Rate: 6656 Kbps
As Jelv says, this figure indicates that your line has been banded. As he also says, hang fire for 24 hours then request an SNR reset
B.
Re: ADSL to ADSL2+
13-01-2013 10:40 AM
Re: ADSL to ADSL2+
13-01-2013 10:47 AM
Re: ADSL to ADSL2+
13-01-2013 11:06 AM
Re: ADSL to ADSL2+
13-01-2013 11:09 AM
Re: ADSL to ADSL2+
13-01-2013 11:15 AM
DSL VPI/VCI: 0/38
DSL Mode: ADSL2+
DSL Channel:
DSL Upstream Rate: 1123 Kbps
DSL Downstream Rate: 4544 Kbps
Down up
DSL Noise Margin: 30.9 dB 6.2 dB
DSL Transmit Power: 0.0 dBm 10.8 dBm
Re: ADSL to ADSL2+
13-01-2013 11:36 AM
Quote from: jelv For some reason SNR resets sometimes fail...
In my experience they often fail if the profile has been banded.
Re: ADSL to ADSL2+
13-01-2013 12:01 PM
Re: ADSL to ADSL2+
13-01-2013 12:12 PM
Something is clearly amiss here. I suggest raising a slow speed fault at http://faults.plus.net to get this looked at properly.
Re: ADSL to ADSL2+
23-01-2013 5:16 AM
DSL VPI/VCI: 0/38
DSL Mode: ADSL2+
DSL Channel:
DSL Upstream Rate: 1187 Kbps
DSL Downstream Rate: 23752 Kbps
Down up
DSL Noise Margin: 3.5 dB 6.1 dB
DSL Transmit Power: 0.0 dBm 12.2 dBm
Re: ADSL to ADSL2+
23-01-2013 11:36 AM
I've bumped your line profile according to your sync rate, so it's now at 20.9Mb/s, you should be seeing speeds close tho that, although it will tend to be slightly lower. If there's a big difference then it's a concern if it's not then it's fine.
Re: ADSL to ADSL2+
23-01-2013 1:13 PM
Re: ADSL to ADSL2+
23-01-2013 2:27 PM
