ADSL to ADSL2
Lesleyann500
ADSL to ADSL2
Currently my account is set to ADSL1, my exchange supports ADSL2.
Please move me over to ADSL2, I understand it won't necessarily increase speed.
10 REPLIES 10
Oldjim
Resting Legend
Fixes: 63
Re: ADSL to ADSL2
When does your exchange say that 21CN was added as Plusnet would not normally provision you on 20CN if 21CN was available unless you were on 20CN with BT
If you carry out the BT speedtest - further diagnostics what are the results
Can you post your router stats as it is possible that you are on ADSL1 because of line line
ejs
Aspiring Hero
Fixes: 25
Re: ADSL to ADSL2
You'll never know if ADSL2 is better or worse for your line and equipment if you don't try it.
If your line is provisioned as ADSL2+, if necessary you can then choose ADSL2+, ADSL2 or ADSL1 by configuring your modem/router accordingly.
I did find a possible source for the "ADSL2+ no benefit" claim:
Quote from: https
ADSL1 or upto 8Mbps on longer lines may offer the optimum service when compared with ADSL2+ upto 20Mbps, under certain conditions (Lines over 4Km's/40dB) there may not be potentially a performance gain by upgrading to ADSL2+
I have never seen any valid explanation for that. Also, according to kitz's max speed calc, 40dB line attenuation is about 2.9km, 4km is more like 55dB.
Lesleyann500
Re: ADSL to ADSL2
The router fails to sync  when trying to force ADSL2/ADSL2+ modulation so I believe I have been provisioned ADSL1.
I'm interested to see how my 52dB line performs with ADSL2/ADSL2+.
jelv
Fixes: 10
Re: ADSL to ADSL2
Please run the BT diagnostic speed tests and post the full results as Jim requested.
http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
x47c
Re: ADSL to ADSL2
Quote from: ejs
On long lines the higher frequencies as used by the full ADSL2+ service deteriorate into just 'noise'.
The attenuation of a signal at at specific frequency is much higher as the frequency used is increased
So the presence on the line of this junk/noise actually makes the line performance worse
Such lines benefit for deliberately restricting the ADSL output from the the DSALM to ADSL1/2 and not having the ADSL2+ "extra" part also there.
ejs
Aspiring Hero
Fixes: 25
Re: ADSL to ADSL2
Yes, but once the line enters showtime, and none of the higher tones have any bits allocated to them, is there any signal output on those frequencies?
x47c
Re: ADSL to ADSL2
Yes,  So far as I understand it the DSLAM will still be outputting the higher frequencies regardless if the line is on ADSL2+
So while the router makes the decision that it cannot understand the data on say any specific frequency and allocates zero bit loading to it, the Dslam is still pumping it out.
By the time the BB signal has reach this sample long line those higher frequencies will have just become wideband 'general noise' across the entire frequency spectrum - making a general mess of the line's performance.
If you set the router to only work say on ADSL1 on a long line it will simply ignore the higher frequencies components of the signal and stop at the max ADSL1 frequency when analyzing the line at sync - above which in our example are unintelligible anyway - but you have to get the ISP to set the line to ADSL1 at their end if you want the DSLAM to stop sending out the higher frequencies in the first place.
From what I've seen/heard the main effect of removing the unused higher frequencies from a long line and restricting to either ADSL1 or plain 2 seems to be on stability rather than achieved sync level.  As a guess I'd say that the general mush of the disturbing ADSL2+ higher frequencies present creates a highly variable level of interference minute by minute on the line
PeeGee
Re: ADSL to ADSL2
My line (4.53km/61.9dB attn) increased a little short of 50% moving from ADSL to ADSL2 (and increased a further 50% since then) and never negotiated ADSL2+ for any significant (usable) time*. It normally uses tones up to 159 @6dB (currently 143 @7.5dB) with error rates escalating rapidly if higher tones (= lower SNRM) get used. I've only done a cursory check, but at least a few tones at the "upper limit" seem to get a bit or two allocated for short intervals - possibly when the tones below are reliable?
Phil
* I now limit to ADSL2 and, subjectively, it seems to re-sync slightly quicker Roll_eyes
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
ejs
Aspiring Hero
Fixes: 25
Re: ADSL to ADSL2
Sorry x47c, but I think that your understanding is just completely wrong. Do you have any sources for it that you can provide links to?
If the line is operating on ADSL1 or ADSL2 (not 2+), regardless of which end selected it, then the DSLAM isn't going to be outputting anything on the 2+ frequencies.
I know my line syncs at higher rates with the modem set to ADSL1 or ADSL2, you don't need anything changed at the exchange.
Quote from: ITU
During the exchange process, each receiver shares with its corresponding far-end transmitter certain transmission settings that it expects to see. Specifically, each receiver communicates to its far-end transmitter the number of bits and relative power levels to be used on each DMT subcarrier, as well as any messages and final data rates information.
Pettitto
Fixes: 5
Re: ADSL to ADSL2
Hi Lesleyann500,
I've placed the order for you, this should complete tomorrow morning for you. If the changes aren't that great or are worse, it'll only take 24 hours to revert back to ADSL1 Smiley
