ADSL speed problems
Fixes: 159
Re: ADSL speed problems
If you have noise on the line with just the phone plugged in, then in the first instance you should pursue a POTS phone line fault.
weeally46
@Townman
Hi, just to let you know plusnet set the SNR to 6db and low and behold its back to normal. Hopefully thats it fixed. Thanks for all the input and advice.
Fixes: 159
For the moment until the DLM cuts in again.
Whilst there’s noise, you are most likely to encounter repeat problems.
weeally46
@Townman I will monitor it and report any issues to plusnet.
