ADSL dropping every 30 minutes?
- ADSL dropping every 30 minutes?
- « Previous
- Next »
Re: ADSL dropping every 30 minutes?
01-04-2016 10:10 PM
02-04-2016 12:55 AM
adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 8000
Last initialization procedure status: 0
Max: Upstream rate = 1260 Kbps, Downstream rate = 12988 Kbps
Bearer: 0, Upstream rate = 1255 Kbps, Downstream rate = 12923 Kbps
Link Power State: L0
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.0 5.6
Attn(dB): 23.0 12.3
Pwr(dBm): 0.0 12.7
ADSL2 framing
Bearer 0
MSGc: 51 12
B: 230 38
M: 1 1
T: 2 4
R: 0 0
S: 0.5707 0.9873
L: 3238 316
😧 1 1
Counters
Bearer 0
SF: 2513821 413356
SFErr: 68 62
RS: 0 2475457
RSCorr: 0 0
RSUnCorr: 0 0
Bearer 0
HEC: 195 50
OCD: 5 0
LCD: 5 0
Total Cells: 1246333217 120888476
Data Cells: 65405131 5423673
Drop Cells: 0
Bit Errors: 8362 3791
ES: 311 272
SES: 21 0
UAS: 161 161
AS: 40900
Bearer 0
INP: 0.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 16.26 17.77
OR: 28.03 8.10
AgR: 12901.60 1259.08
Bitswap: 288/288 17/17
Total time = 1 days 3 hours 17 min 4 sec
FEC: 0 0
CRC: 1311 476
ES: 311 272
SES: 21 0
UAS: 161 161
LOS: 2 0
LOF: 18 0
LOM: 0 0
Latest 15 minutes time = 2 min 4 sec
FEC: 0 0
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 3 hours 17 min 4 sec
FEC: 0 0
CRC: 23 0
ES: 21 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 0 0
CRC: 1121 249
ES: 148 141
SES: 21 0
UAS: 107 107
LOS: 2 0
LOF: 18 0
LOM: 0 0
Since Link time = 11 hours 21 min 39 sec
FEC: 0 0
CRC: 68 62
ES: 61 38
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Attenuation
02 Apr 2016 00:47:21 23.0 12.3
02-04-2016 12:57 AM
02-04-2016 10:44 AM
With regard to the graphs, if you can adjust the bit scaling to cover all 512 tones, but IIRC there can be a bit of a compromise because the scale is either too much (so plots are a bit squashed up) or too little (as you have) - it's a long while since I used DSLstats and I don't use it as it fills the 582n log up with constant login/logout messages and so other important information is lost from the log (unlike RouterStats which works with the 582n).
If you can change the graphing of the ES errors to be real time, that could help. Other than that, I don't know if you can identify when that burst of ES errors occurred.
02-04-2016 1:27 PM
I'll attach the new graphs - I've got one with up to 375 so the scale is still reasonable, but the next one is up to 750 which is a bit too much 😕
For the error seconds, should I leave it to log with the sample time set to 1 second or something?
02-04-2016 6:40 PM
It wasn't the sampling frequency so much that I was talking about rather than the x-axis scale and the plotting. If that could be real time rather than "Hour".
As far as Bit plotting goes, I think the 750 scale will do for now. ADSL2+ goes to tone 511. And upto ~tone 440 everything looks pretty good and what might be expected, but then the sharper drop-off to ~tone 500 and the small peak after that is somewhat unusual.
Haven't got any Radio Amateurs living near you by any chance?
02-04-2016 7:59 PM
As for radio amateurs nearby, I honestly have no idea!
No more LOF or LOS errors so far today, and the link hasn't dropped either. Maybe whatever was going on was just a chance issue...
DSLAM/MSAN type: IFTN:0x71c8 / v0x71c8
Modem/router firmware: AnnexA version - A2pv6F039i.d24e
DSL mode: ADSL2+
Status: Showtime
Uptime: 1 day 6 hours 36 min 13 sec
Resyncs: 0 (since 02 Apr 2016 20:02:02)
Downstream Upstream
Line attenuation (dB): 23.0 12.3
Signal attenuation (dB): 25.2 12.6
Connection speed (kbps): 12923 1255
SNR margin (dB): 9.1 6.1
Power (dBm): 0.0 12.7
Interleave depth: 1 1
INP: 0 0
G.INP: Not enabled Not enabled
RSCorr/RS (%): N/A 0.0000
RSUnCorr/RS (%): N/A 0.0000
ES/hour: 6.71 1.87
Status: Showtime
Max: Upstream rate = 1260 Kbps, Downstream rate = 13032 Kbps
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 9.1 5.8
Attn(dB): 23.0 12.3
Pwr(dBm): 0.0 12.7
ADSL2 framing
Bearer 0
MSGc: 51 12
B: 230 38
M: 1 1
T: 2 4
R: 0 0
S: 0.5707 0.9873
L: 3238 316
😧 1 1
Counters
Bearer 0
SF: 6773454 536863
SFErr: 223 140
RS: 0 4051150
RSCorr: 0 0
RSUnCorr: 0 0
Bearer 0
HEC: 555 151
OCD: 9 0
LCD: 9 0
Total Cells: 3358225859 325781300
Data Cells: 224432013 16678169
Drop Cells: 0
Bit Errors: 21943 9060
ES: 439 313
SES: 21 0
UAS: 161 161
AS: 110205
Bearer 0
INP: 0.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 16.26 17.77
OR: 28.03 8.10
Bitswap: 438/438 30/30
Total time = 1 days 22 hours 32 min 9 sec
FEC: 0 0
CRC: 1466 554
ES: 439 313
SES: 21 0
UAS: 161 161
LOS: 2 0
LOF: 18 0
LOM: 0 0
Latest 15 minutes time = 2 min 9 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 0 0
CRC: 5 0
ES: 5 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 22 hours 32 min 9 sec
FEC: 0 0
CRC: 178 78
ES: 149 41
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 0 0
CRC: 1121 249
ES: 148 141
SES: 21 0
UAS: 107 107
LOS: 2 0
LOF: 18 0
LOM: 0 0
Since Link time = 1 days 6 hours 36 min 43 sec
FEC: 0 0
CRC: 223 140
ES: 189 79
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
02-04-2016 9:45 PM
As far as Radio Amateurs go, you'd notice some very large aerials, some much bigger than the old 405 lines TV aerials and FM aerials, also some "Long Wire" aerials which would be needed for "Top Band" which is an amateur band operating 1.8-2.0Mhz which covers some of those tones around 430-480. Just trying to think of possible explanations for that unusual bit loading. It could of course be due to some other electronic equipment which might generate those sort of frequencies.
03-04-2016 2:12 PM
Definitely could be other electronics, the modem is in the study with a heap of other gear. I'll try and get rid of whatever I can nearby and try logging then
03-04-2016 2:58 PM
If you go a lengthy period now without anything happening, start switching on the stuff that's normally left on, only one at a time, leave it on for a good period and see if anything happens.
- « Previous
- Next »
