ADSL & ADSL2 Routers - difference?
- ADSL & ADSL2 Routers - difference?
24-11-2009 10:48 PM
currently I have an Linksys WAG54G ADSL for ADSL2 would I need to change my router to an ADSL2 box? or can it be done with a firmware update?
Thanks.
Thanks.
Message 1 of 3
(1,247 Views)
2 REPLIES 2
Re: ADSL & ADSL2 Routers - difference?
24-11-2009 11:07 PM
i belive it is an adsl2+ router, thoe keeping up with the latest firmware is allways the best thing to do
Message 2 of 3
(381 Views)
24-11-2009 11:09 PM
What hardware version of WAG54G do you have ?, and what firmware revision is it running ?
I have had four different hardware versions of WAG54G with varying levels of capability !.
You might want to look at http://www.linksysbycisco.com/UK/en/support and enter your WAG54G hardware version, then check the firmware releases, and check the latest handbook pdf for your equipment's capability.
Message 3 of 3
(381 Views)
