ADSL+ Filters
- Re: ADSL+ Filters
ADSL+ Filters
17-02-2012 5:40 PM
What is best ..an NTE5 type faceplate on master socket or a splitter/filter/dongle in the master socket?
Message 1 of 6
(1,395 Views)
5 REPLIES 5
Re: ADSL+ Filters
17-02-2012 6:46 PM
I believe the faceplates are regarded as better but I'm unsure if thats functually better or aesthetically.
Message 2 of 6
(534 Views)
Re: ADSL+ Filters
17-02-2012 6:56 PM
I have tried, experimented and measured all sorts of faceplates, filters, and cables, on my own and other peoples phone lines.
I have ALWAYS found that the ADSLNation XTE-2005 faceplate gives the best result, along with four-core round profile RJ11 modem cables.
Message 3 of 6
(534 Views)
Re: ADSL+ Filters
18-02-2012 12:14 AM
Quote from: moemoff What is best ..an NTE5 type faceplate on master socket or a splitter/filter/dongle in the master socket?
Depends. If you've got extension sockets, used or not, the faceplate will be better, as all the extension wiring will be on the non-ADSL side of the filter.
If there are no extensions, then using a good quality dongly filter will be just as good.
In the latter case I'd go for the faceplate anyway on aesthetic grounds.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 4 of 6
(534 Views)
Re: ADSL+ Filters
18-02-2012 2:18 PM
I have a XTE-2005 faceplate filter and it is very good I would say the best I have used
Message 5 of 6
(534 Views)
Re: ADSL+ Filters
20-02-2012 12:10 PM
Thank you all!
I am going for the XTE-2005 faceplate filter because I need one extension. I did have the old BT ADSL 1.01 at one time but it was recently taken off by a BT engineer who was solving a line noise (telephone) problem.Turned out it was an external problem in their underground box. Was left with a dongle and the speed went down even after the fault was cleared. Have a SNR margin of 8 and loop att of 29. Used to be SNR of 6 and loop att of 24 before the fault developed. But it was rock steady.
Anyways.. thanks to all again.
Mo
Mo
Message 6 of 6
(534 Views)
