ADSL Down
- ADSL Down
ADSL Down
01-05-2013 2:10 AM
My router can't pick up a PPP link (red broadband light).
Is there an outage?
EDIT: Oh, maintenance in Birmingham.
https://portal.plus.net/supportpages.html?a=2&support_action=maintenance&ispservice_id=adsldial
Is there an outage?
Message 1 of 4
(760 Views)
3 REPLIES 3
Re: ADSL Down
01-05-2013 11:01 AM
We would only have expected you to be disconnected for perhaps a short while during the maintenance window (between midnight and 6am)
I'd give your router a reboot and failing that head for our fault checker: http://faults.plus.net
Adam
Adam
Message 2 of 4
(346 Views)
Re: ADSL Down
01-05-2013 5:36 PM
Thanks, back online now albeit with 2000 Kbps slower sync. I thought my DLM was disabled?
Message 3 of 4
(346 Views)
Re: ADSL Down
02-05-2013 12:59 PM
It is, but that means the profile won't adjust to the new sync rate. Sync still depends on line quality and is still variable as far as I know - but on the bright side if you do sync faster you'll get that speed back again straight away
Message 4 of 4
(346 Views)
