ADSL Broadband Speed has nose-dived just over a week from connection
FIXED- Subscribe to RSS Feed
- ADSL Broadband Speed has nose-dived just over a we...
27-10-2016 6:34 PM
1 - Product name: | Plusnet Router |
2 - Serial number: | N7161891B001108 |
3 - Firmware version: | 7.275.2_F2704N_Plusnet |
4 - Board version: | F@ST2704N |
5 - Mode | ADSL |
6 - Uptime: | 0 days 16:32:26 |
7 - Data rate: | 152/4011 |
8 - Maximum data rate: | 148/3648 |
9 - Noise margin: | 5.5/4.8 |
10 - Line attenuation: | 54.9/52.0 |
12 - Data sent/received: | 170.0M/2.2G |
20 - Broadband username: | *******@plusdsl.net |
21 - Wi-Fi network/SSID: | *********** |
22 - Wi-Fi connections: | Enable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS enabled |
23 - Wi-Fi security: | WPA2 |
24 - Wi-Fi channel: | 13 |
25 - Firewall: | Default |
26 - MAC Address: | 24:7f:20:2e:d0:e5 |
27 - Software variant | Version 1.0 |
28 - Boot loader: | 7.275.2 |
Fixed! Go to the fix.
Re: ADSL Broadband Speed has nose-dived just over a week from connection
27-10-2016 6:51 PM
Am using Wired Ethernet Cable to PC so I get a little more speed.
Did reboot the router early on (via router log in) to do BT Wholesale Speed Test
Broadband Speed Test Results
3.44 / 0.09 & 80.25 ms (just now on Ethernet)
1.58 / 0.12 & 16ms on wifi (ios app)
Download speedachieved during the test was - 3.44 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 3.54 Mbps
Upload speed achieved during the test was - 0.09Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Started off on about 13.
Should be 10 - 19.5 (average 17)
27-10-2016 6:59 PM
The line attenuation figures indicate a problem somewhere.
What are the router stats like when you connect to the test socket?
27-10-2016 7:05 PM
Hi Browni
Will it be ok to unplug router to test behind the bt socket plate or will it upset the DLM (line training) ?
27-10-2016 7:08 PM
Yep. One or two disconnections are normally fine, it's repeated disconnections that upset DLM.
27-10-2016 7:34 PM
HI Browni
Openreach socket base-plate removed - ethernet wired test
Download speedachieved during the test was - 13.82 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 14.49 Mbps
Upload speed achieved during the test was - 1Mbps
wifi ios app: 5.49 / 1.85 & 8ms
5 - Mode | ADSL |
6 - Uptime: | 0 days 00:10:11 |
7 - Data rate: | 1203/16427 |
8 - Maximum data rate: | 1200/16464 |
9 - Noise margin: | 6.1/6.0 |
10 - Line attenuation: | 14.7/26.5 |
12 - Data sent/received: | 12.6M/446.9M |
20 - Broadband username: | ********@plusdsl.net |
21 - Wi-Fi network/SSID: | ************ |
27-10-2016 8:10 PM
Openreach faceplate back on and just phone and broadband connected. Ethernet test
Download speedachieved during the test was - 14.35 Mbps
IP Profile for your line is - 14.48 Mbps
Upload speed achieved during the test was - 0.73Mbps
5 - Mode | ADSL |
6 - Uptime: | 0 days 00:02:10 |
7 - Data rate: | 1203/16411 |
8 - Maximum data rate: | 1204/16456 |
9 - Noise margin: | 6.1/6.1 |
12 - Data sent/received: | 258.5K/5.0M |
20 - Broadband username: | *********@plusdsl.net |
27-10-2016 8:56 PM - edited 27-10-2016 8:58 PM
Now that's a lot better.
When the speed was slower was everything connected filtered?
Also, have another look at my link above and see if removing the ring wire will help.
27-10-2016 9:28 PM
Hello Browni
Thanks for reply...
The WIFI has such a variable range of 1.7 to 13.82
Some Drop-outs (can't see / pick-up router) occur though restarting/resetting windows 10 or resetting ipad mini 2 wifi can help
27-10-2016 10:07 PM
Hi Again Browni
Because WIFI speed is so variable for me it's hard to attribute the cause, though it has mysteriously improved tonight
I'll bear your ring wire link in mind. (though slight hesitation in fiddling with old 1960's wires)
I badgered Openreach to fit the NTE5 socket as i had a relic there before!! (after low speeds with last isp probable cause a faulty DSLAM)
I went temporarily on an extension lead to use an ethernet cable, as wifi was so bad (two filters (phone and end of extension) BUT wifi stayed the same until tonight !!!
27-10-2016 11:56 PM
There's two issues here, WiFi and your internal wiring.
Concentrating on the wiring issue your first post contained the following stats
7 - Data rate: 152/4011
8 - Maximum data rate: 148/3648
9 - Noise margin: 5.5/4.8
10 - Line attenuation: 54.9/52.0
After connecting to the test socket these improved greatly to
7 - Data rate: 1203/16427
8 - Maximum data rate: 1200/16464
9 - Noise margin: 6.1/6.0
10 - Line attenuation: 14.7/26.5
Which shows that there is an issue with the internal wiring which needs sorting out before anything else. Common causes of this are the ring wire which I mentioned above and unfiltered devices.
Your third set of router stats have me confused.
7 - Data rate: 1203/16411
8 - Maximum data rate: 1204/16456
9 - Noise margin: 6.1/6.1
Everything looks fine here so what was different between this and your initial post?
28-10-2016 2:11 AM - edited 28-10-2016 2:50 AM
Hi Browni
Thanks for replying........
Wifi speed (master socket) 7.05 to 14.10 after musical chairs. (have put router up higher now)
It just so funny that before musical chairs wifi was below 2 (master and extension) and between 2 to 4 on Ethernet (ext lead)
I had o2 BB (which closed down) on the extension lead without problems. (With my last ISP I didn't with the DSLAM probs)
My Dect phone has been lighting up for a few nights with line cord error which is strange though a dial tone and tried 17070 (2) and no crackle or pop
Edit to add
via Wifi router stats:
5 - Mode | ADSL |
6 - Uptime: | 0 days 05:50:56 |
7 - Data rate: | 1199/16395 |
8 - Maximum data rate: | 1204/16480 |
9 - Noise margin: | 6.2/6.0 |
12 - Data sent/received: | 133.7M/3.0G |
20 - Broadband username: | ******@plusdsl.net |
21 - Wi-Fi network/SSID: | ******** |
01-11-2016 8:53 PM
Update:
Been behaving itself ever since.....
Been getting around 13 Mbps so good performance.
