ADSL 2+ Sounds good to me
- Re: ADSL 2+ Sounds good to me
23-05-2012 10:41 PM
Looking at the recent posts prompted me to check the position on my exchange. BT Wholesale and Samknows both seem to indicate that either now or imminently ADSL 2+ should be available to me. So can I request an upgrade please in the hope that it might make Iplayer on my tv a source for cheerful kids rather than of teenage cursing (that's in the room rather than on screen by the way). And then there's the forthcoming olympics - buffering during a handball match on BBC's web coverage needs to be avoided if possible, or perhaps not.
One of many things that I don't understand - is there a difference between ADSL2+ and W21CN or are they the same thing? Does a W21CN exchange improve ADSL2+ ? I'd be interested to know so that if anyone asks why my line speed has got quicker (fingers crossed) I could attempt to explain.
Message 1 of 6
(1,244 Views)
5 REPLIES 5
24-05-2012 12:25 AM
You cannot have ADSL2(+) unless you are on a 21CN exchange. 20CN exchanges only provide standard ADSL.
Whether you get the full benefit of ADSL2+ depends on the length and quality of your line, you may only get ADSL2 upto 12Mbps is your line is longish and/or poor quality, very long lines may only get ADSL1. You do however get the benefits of 21CN profiling which is 88.2% of the sync speed.
Message 2 of 6
(568 Views)
24-05-2012 8:02 PM
Thanks for the info Anotherone.
I've done some more checking and it appears that my exchange is now 21CN. So please Plusnet can I have an upgrade.
Message 3 of 6
(568 Views)
25-05-2012 1:57 PM
Hi Keymer,
I've placed an order for that for you. It should be complete on the 1st June. I've also sent a ticket/email confirmation to you.
Jojo
Jojo
Message 4 of 6
(568 Views)
30-05-2012 9:52 PM
Thanks Jojo,
Is there anything that I need to do on 1 June? Should I leave my router switched on as normal, or do I need to log out, turn it off, leave it for a bit and then turn it back on at some stage during the day? Is it right that I can then expect the speed to fluctuate for up to 10 days before the connection optimises?
Message 5 of 6
(568 Views)
30-05-2012 9:59 PM
Just leave it router on - no need to re-boot or anything
I was actually working at the instant when my line was swapped.
Everything on the web suddenly 'stopped' late morning
I guessed what was being done
So I went away and had a cup of coffee
When I returned router had re-sync'd at the new ADSL2+ sync speed.
...and I carried on from where I had left off.
Message 6 of 6
(568 Views)
