ADSL 2+ (NOT UK related) - Advice requested. (O/T)
- ADSL 2+ (NOT UK related) - Advice requested. (O/T)
17-04-2009 8:43 AM
I appreciate this may not be the correct forum, but the expertise lies here.
My second home in France has had ADSL2+ for over two years. We have been with the same ISP the whole time. When visiting at Easter, we noticed the following:
> adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime Channel: INTR, Upstream rate = 320 Kbps, Downstream rate = 1216 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Interleave
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 31.8 23.0
Attn(dB): 35.0 19.0
Pwr(dBm): 17.6 11.1
Max(Kbps): 7936 1040
Rate (Kbps): 1216 320
G.dmt framing
K: 39(0) 11
R: 2 16
S: 1 16
😧 16 2
ADSL2 framing
MSGc: 1 1
B: 39 11
M: 1 16
T: 1 1
R: 2 16
S: 1.0500 17.3333
L: 320 96
😧 16 2
Counters
SF: 10324645 10324643
SFErr: 0 0
RS: 702075906 43879732
RSCorr: 34 0
RSUnCorr: 0 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 503375237 0
Data Cells: 1094357 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 0
SES: 0 0
UAS: 18 0
Total time = 1 days 40 min 51 sec
SF = 10324645
CRC = 0
LOS = 0
LOF = 0
ES = 0
Latest 1 day time = 40 min 51 sec
SF = 144196
CRC = 0
LOS = 0
LOF = 0
ES = 0
Latest 15 minutes time = 10 min 51 sec
SF = 38291
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 15 minutes time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 1 day time = 24 hours 0 sec
SF = 5082319
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52982
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
I find the interesting point here is:
Down Up
Rate (Kbps): 1216 320n
Two years ago we got 11Mb down and 1.5 Mb up.
Does anyone, with their excellent technical knoweldge, know what maybe causing the router to see G.DMT instead of ADSL2+? I have tried turning off G.DMT and noticed that the router would not sync.
Any help greatfully received. I can telnet to the router, but amazingly my ISP refuses to do the same as they are only skilled in the web interface.
Thanks in advance.
> adsl info --stats
Mode: G.DMT
Channel: Interleave
Trellis: ON
Down Up
SNR (dB): 31.8 23.0
Attn(dB): 35.0 19.0
Pwr(dBm): 17.6 11.1
G.dmt framing
K: 39(0) 11
R: 2 16
S: 1 16
😧 16 2
ADSL2 framing
MSGc: 1 1
B: 39 11
M: 1 16
T: 1 1
R: 2 16
S: 1.0500 17.3333
L: 320 96
😧 16 2
Counters
SFErr: 0 0
RSCorr: 34 0
RSUnCorr: 0 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 0
SES: 0 0
UAS: 18 0
SF = 10324645
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 144196
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 38291
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 5082319
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 52982
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
Down Up
Thanks in advance.
Message 1 of 1
(743 Views)
