ADSL 2+ IP Profile Stuck.
- ADSL 2+ IP Profile Stuck.
Re: ADSL 2+ IP Profile Stuck.
11-11-2014 1:34 PM
Just running my script with the pingpath and tracert see what results i get from that as well.
@Chris i have sent you a PM with the full firewall log.
11-11-2014 1:52 PM
11-11-2014 3:07 PM
Here is my current pingpath and tracert's
Tracing route to plus.net [212.159.8.2]
over a maximum of 30 hops:
1 4 ms 3 ms 4 ms home.hillisde.hillside.home [192.168.1.254]
2 36 ms 35 ms 30 ms lo0-central10.pcl-ag03.plus.net [195.166.128.184]
3 26 ms 30 ms 31 ms link-a-central10.pcl-gw01.plus.net [212.159.2.168]
4 31 ms 19 ms 25 ms xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
5 25 ms 22 ms 30 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 26 ms 19 ms 20 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
7 48 ms 48 ms 51 ms gi5-1.peh-cr02.plus.net [84.93.232.61]
8 33 ms 33 ms 34 ms po5.peh-cr01.plus.net [84.93.232.16]
9 49 ms 29 ms 28 ms vlan2657.peh-elb01.plus.net [84.93.232.44]
10 33 ms 41 ms 44 ms portal.plus.net [212.159.8.2]
Trace complete.
Tracing route to portal.plus.net [212.159.8.2]
0 solidus1983-gmc.hillside.home [192.168.1.105]
1 home.hillisde.hillside.home [192.168.1.254]
2 lo0-central10.pcl-ag03.plus.net [195.166.128.184]
3 link-a-central10.pcl-gw01.plus.net [212.159.2.168]
4 xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
5 ae1.ptw-cr01.plus.net [195.166.129.0]
6 te9-4.ptn-gw01.plus.net [195.166.129.33]
7 gi5-1.peh-cr02.plus.net [84.93.232.61]
8 po5.peh-cr01.plus.net [84.93.232.16]
9 vlan2657.peh-elb01.plus.net [84.93.232.44]
10 portal.plus.net [212.159.8.2]
Computing statistics for 250 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0/ 100 = 0% |
1 32ms 0/ 100 = 0% 0/ 100 = 0% home.hillisde.hillside.home [192.168.1.254]
0/ 100 = 0% |
2 44ms 0/ 100 = 0% 0/ 100 = 0% lo0-central10.pcl-ag03.plus.net [195.166.128.184]
0/ 100 = 0% |
3 36ms 0/ 100 = 0% 0/ 100 = 0% link-a-central10.pcl-gw01.plus.net [212.159.2.168]
0/ 100 = 0% |
4 33ms 0/ 100 = 0% 0/ 100 = 0% xe-10-2-0.pcl-cr01.plus.net [212.159.0.200]
0/ 100 = 0% |
5 38ms 0/ 100 = 0% 0/ 100 = 0% ae1.ptw-cr01.plus.net [195.166.129.0]
0/ 100 = 0% |
6 36ms 0/ 100 = 0% 0/ 100 = 0% te9-4.ptn-gw01.plus.net [195.166.129.33]
0/ 100 = 0% |
7 41ms 0/ 100 = 0% 0/ 100 = 0% gi5-1.peh-cr02.plus.net [84.93.232.61]
0/ 100 = 0% |
8 42ms 0/ 100 = 0% 0/ 100 = 0% po5.peh-cr01.plus.net [84.93.232.16]
0/ 100 = 0% |
9 52ms 0/ 100 = 0% 0/ 100 = 0% vlan2657.peh-elb01.plus.net [84.93.232.44]
0/ 100 = 0% |
10 50ms 0/ 100 = 0% 0/ 100 = 0% portal.plus.net [212.159.8.2]
Trace complete.
11-11-2014 3:10 PM
11-11-2014 6:49 PM
12-11-2014 9:18 AM
12-11-2014 12:33 PM
It seems better but i really do not know whom i upset for such a constant attack on our connection. Did you get my PM?
12-11-2014 12:56 PM
12-11-2014 1:01 PM
I don't run servers at home due to lack of bandwidth.
@chris just sent another PM to you with what i am getting now and wireshark.
12-11-2014 1:02 PM
12-11-2014 1:05 PM
Edit: Done, DDNS is now Disabled will keep eye on the logs now.
Edit2: Nope still getting them attacks will PM you the log from firewall again.
Edit3: Packet and Latency issue is back, nothing in firewall and was noticed during game play lucky i record my game play so i am now cutting the video slightly to show the issue. It has the network graph as well and then it will show you what i am facing.
Here is the Video Look closely at the graph at the bottom middle of the screen you will see Loss -> (packetloss from my end to server) and Also latency too.
https://www.youtube.com/playlist?list=PLd5jL7yWiZYgJrEFhRjUHS94NtnFqPnWQ
13-11-2014 9:34 AM
Also, sorry if we've asked this, but are you running wireless or wired?
13-11-2014 11:13 AM
13-11-2014 11:20 AM
13-11-2014 2:45 PM
Edit: To answer your other question. Happens just the same on Wireless as it does on Wired. (The first check i did and the Video that was recorded was on Wired!) Also i was the only users at the time on the internet. All other devices was knocked offline as well as all the background processes on the system.
However the wireshark i did was on wired as on my laptop i have load balancing setup due to the system i have.
I am also using the 20hz Wifi signal over the more common 20/40hz which would give me 300mbps instead of the 144mbps i am getting now to insure that there is no interference also the channel being used is stuck at 1 as not to overlap any other Wifi Signal and this gets changed once an overlap is found.
How ever i can rest assure you its not the wifi as i can stream 1080P @30fps games over wifi on my Tablet from the laptop, without using Wired connection.
