ADMIN Does my profile need a nudge in the righ direction please
- Re: ADMIN Does my profile need a nudge in the righ...
10-10-2011 11:40 AM
Download Speed
1791 Kbps
0 Kbps 2000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1791 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :4352 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
Phone exchange:
BOGNOR REGIS
Estimated line speed:
3.0Mb (This may vary between 2Mb and 5.5Mb) - Checked on 2011-05-19 18:10:23
Current line speed:
2 Mb
thanks
Re: Does my profile need a nudge in the righ direction please
10-10-2011 1:29 PM
Re: ADMIN Does my profile need a nudge in the righ direction please
10-10-2011 1:43 PM
10-10-2011 5:04 PM
As Jim says, there's nothing we can do to alter the BT profile I'm afraid and that's still set at 2000. The only way to affect that is to minimise interference on the line by making sure the router is in the master socket and all other used extensions are filtered.
11-10-2011 5:51 PM
ROUTER STATS
System Up Time 5 days 04:12:54
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN pppoa 3390507 5282500 0 911 4772 5 days 04:12:35
LAN1 Link Down -- -- -- -- -- --
LAN2 Link Down --
LAN3 Link Down --
LAN4 Link Down --
WLAN 145M 5769022 3880275 0 5628 1580 5 days 04:12:29
ADSL Link Downstream Upstream
Connection Speed 4352 kbps 448 kbps
Line Attenuation 57.0 db 27.0 db
Noise Margin 5.8 db 23.0 db
BT TEST
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
1760 Kbps
0 Kbps 2000 Kbps
Download speedachieved during the test was - 1760 Kbps
11-10-2011 5:58 PM
12-10-2011 9:49 AM
I've just checked the line and all profiles on BTs side and ours are showing as consistent at 3500, is the BT speed test still reporting 2000?
12-10-2011 10:14 AM
just checked and sometime between last night and this morning it changed and everything move that bit smoother and faster
thanks
15-10-2011 11:04 PM
Current line speed:
1.75 Mb
my noise margin has gone the highest it has ever been
System Up Time 9 days 09:22:27
WAN pppoa 619352 1004170 0 402 8496 1 day 18:09:32
LAN2 Link Down --
LAN3 Link Down --
LAN4 Link Down --
WLAN 145M 11367378 7411148 0 1297 1364 9 days 09:22:02
Connection Speed 2240 kbps 448 kbps
Noise Margin 15.6 db 22.0 db
and my connection speed has dropped the lowest i have seen it
BT TEST
Download Speed
1536 Kbps
0 Kbps 2000 Kbps
Download speedachieved during the test was - 1536 Kbps
Your DSL Connection Rate :2240 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1750 Kbps
17-10-2011 10:18 AM
17-10-2011 11:03 AM
17-10-2011 11:11 AM
17-10-2011 11:19 AM
The worry is that your default noise margin has been increased to from 6dB to 15dB and then you won't see much, if any, improvement
17-10-2011 11:33 AM
System Up Time 00:02:16
WAN pppoa 466 496 0 759 2994 00:01:42
LAN2 Link Down --
LAN3 Link Down --
LAN4 Link Down --
WLAN 145M 2712 2496 0 10098 3304 00:01:51
Connection Speed 2336 kbps 448 kbps
BT TEST
Download Speed
1539 Kbps
0 Kbps 2000 Kbps
Download speedachieved during the test was - 1539 Kbps
Your DSL Connection Rate :2336 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
17-10-2011 12:26 PM
You need to get a better sync rate for your profile to go back up. Can you plug into the test socket and see if your sync rate improves.
Jojo
