A question about microfilters
mashwo67
Is it recommended that microfilters be plugged in to all sockets in my flat, even those that are not in use (no phone or other equipment plugged in)
4 REPLIES 4
Fixes: 22
Re: A question about microfilters
Welcome to the forums, @mashwo67.
You only need microfilters in sockets to which phones or other equipment is connected to.
mashwo67
Cheers John.
Also, is it ok to plug my router in to any socket (with a microfilter) or is it preferred that the master socket is used for that?
Fixes: 22
You can use any live socket, but the master socket is best.
mashwo67
Thanks John
