A query on running Router Stats
- Re: A query on running Router Stats
28-07-2008 6:58 AM
I'm using with my Netgear router. At present noise margins are logged at minute intervals. If it's there It is likely staring me in the face, ( Ask OH when I'm looking for the car keys or bus pass::)), but I'd like to know if and how one can alter the sampling interval to something less frequent.
Message 1 of 5
(1,293 Views)
4 REPLIES 4
28-07-2008 12:38 PM
Yes, it's staring you in the face
I'm not using RouterStats at the moment so I'm working from memory:
Click on the yellow gear wheel and you'll find it on one of the settings tabs.
Regards .....
Regards .....
Message 2 of 5
(529 Views)
28-07-2008 1:30 PM
@road runner But blowed if I can see it!
Message 3 of 5
(529 Views)
28-07-2008 2:35 PM
Graphs --> Common Settings
Over on the right-hand side there's a box labeled Sample every
Yes?
Regards .....
Yes?
Regards .....
Message 4 of 5
(529 Views)
28-07-2008 3:07 PM
by my blindness!! Found it :). In some ways a pity that the range of intervals is limited.
Message 5 of 5
(529 Views)
