A lowly maxADSL subscriber (LLU not available)
- Re: A lowly maxADSL subscriber (LLU not available)
27-02-2012 10:54 PM
Your details say the following
Phone exchange:
CRONDALL
Estimated line speed:
7Mb (This may vary between 6Mb and 8Mb) - Checked on 2012-02-24 13:06:48
Current line speed:
7.15 Mb
In reality we actually get quite a variation. 0.6MB - 5MB; average is about 1MB. We're about a mile from the exchange (by road). I'm guessing this is conjestion and unless BT do something at the exchange (or we move) we're all screwed. Modem stats follow. Thanks!
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 940 / 9,344
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 120.55
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 15.0 / 27.0
SN Margin (Up/Down) [dB]: 22.0 / 11.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4 / 209
CRC Errors (Up/Down): 5 / 1
HEC Errors (Up/Down): 0 / 0
27-02-2012 11:11 PM
28-02-2012 8:41 AM
you will need to login to see this
Ian
28-02-2012 8:49 AM
Quote Current line speed:
7.15 Mb
the BT speedtest will make sure the two are in line.
28-02-2012 9:47 AM
28-02-2012 9:52 AM
Quote from: Strat Your exchange is showing green here http://usertools.plus.net/exchanges/?exchange=Crondall&exact=1725&plugin=vp
The history for your exchange looks OK (link), but as it's over a month since Plusnet last updated the data I'm not sure if you can rely on the current green status.
Is the speed poor at any particular time of the day and good when general internet usage will be lighter?
28-02-2012 3:16 PM
I'm surprised you can't get better speed. The 0.5Mbps concerns me. As jelv said, are there patterns in the time of day your speed changes?
Jojo
29-02-2012 12:19 PM
Our internet has been slow for years but as we're not big downloaders (apart from after midnight:-) and we've not been too worried. I run speedtesters via ethernet and test socket. A neigbour with talktalk has also been very slow but BT set their profile to 0.5MB (sorry - don't understand the tech speak)...still waiting for that to be sorted.
Question1. I'm on Value which means there;s no (or little) traffic management between midnight and 4pm. What are speedtesters considered as far as Plusnet are concerned? Is that a download, download server or just browsing?
Its been suggested to me that I post some speed test results over the period of a few days. I just started today. This is what I have. Will update in a couple of days. Thanks! (These are using 3 different testers with results averaged; I'm working at home today 🙂
23:45 1.5Mbps 6:12 5.5 9:23 2.7 10:52 4.7 12:15 3 12:45 5.2 16:30 1.5
8:44 3.5 11:48 5.7 12:09 6.1 12:57 6.2 13:22 5.2 18:00 2.0 22:11 0.5 23:45 1.6 00:02 1.3 00:34 2.7
10:24 6.0
29-02-2012 2:58 PM
That does sound like it's slowing down in the evenings when the network does tend to be a lot busier. Hope things do get improved, I'm not sure when the exchange information is due to be updated but I'll check on that too.
04-03-2012 12:58 PM
A picture for you. NB. no readings between 00:30 and 06:30, but I'm sure the bandwidth is fine then!
I just want to know if this is typical for an expected 5.5MB connection. Thanks.
(readings taken Mon-Fri)
07-03-2012 10:33 AM
07-03-2012 10:37 AM
PS. is there a simple tech sentence which describes what has been done as a neigbour, also with PN, is running at 1Meg (or less). Cheers.
07-03-2012 1:44 PM
07-03-2012 1:46 PM
jim:quote
