A few questions regarding ping times
- Re: A few questions regarding ping times
01-04-2012 4:46 AM
Hey guys. When I first had the service my interleaving was off with ping times of 35-40ms, then there were a few errors on my line so plusnet put it on so my ping shot upto 65-70ms..
Firstly am I benefiting from the pro add-on at all? I only use the net for the playstation but my sister uses the laptop at the same time.
If I upgrade to FTTC would my ping stay at 65-70ms or would it be lower?
Also I have done pretty much everything plusnet have told me to do to try and fix the latency issue... I don't understand why it is so high when im only 1.2km from the exchange and I was 4km from it in my old house with lower pings.
Any help would be appreciated, and also would like my interleaving turned back off. Thanks.
Message 1 of 5
(1,198 Views)
4 REPLIES 4
02-04-2012 9:27 AM
I've just checked your account. I can see from ticket 53775431 that your connection has been quite intermittent of late but has become more stable since interleaving was applied.
If you like we can remove this but as you may understand there's a risk that it may start to cause the connection to drop again.
If it does then give me a shout on here and I can make sure we look at any other possible avenues (i.e rather than interleaving) that we can try.
Adam
Adam
Message 2 of 5
(479 Views)
02-04-2012 4:29 PM
I would appreciate it if you turned it off again, thank you.
jim:quote
jim:quote
Message 3 of 5
(479 Views)
02-04-2012 5:21 PM
Message 4 of 5
(479 Views)
05-04-2012 1:16 AM
Thanks Adam, you said "If it does then give me a shout on here and I can make sure we look at any other possible avenues (i.e rather than interleaving) that we can try." Can you tell me what else there is to do? Thanks again.
Message 5 of 5
(479 Views)
