A couple of questions regarding the Technicolor TG582n
- Re: A couple of questions regarding the Technicolo...
01-01-2013 6:15 PM
Now from what I can gather with the USB port on the Technicolor TG582n router, you can use this as a back up connection with a 3G dongle (is this right?). Also can you use the USB port with a USB memory stick and wireless storage?
Message 1 of 6
(1,813 Views)
5 REPLIES 5
Re: A couple of questions regarding the Technicolor TG582n
01-01-2013 6:38 PM
Quote you can use this as a back up connection with a 3G dongle (is this right?)
With some 3g dongles yes, see here for some setup details http://wiki.aa.org.uk/index.php/TG582N#3G_setup ( and the further notes links ). It doesn't do an automatic failover though , you need to manually connect
Quote Also can you use the USB port with a USB memory stick
Yes , as long as its formatted FAT32 ( or plain FAT ).
The current PlusNet supplied ADSL routers don't have a USB port though. Some FTTC ones may still have USB , not sure...
Message 2 of 6
(606 Views)
01-01-2013 6:45 PM
Quote from: MisterW Yes , as long as its formatted FAT32 ( or plain FAT ).
Yes it has a USB port. Also should have said it is the FTTC router.
Message 3 of 6
(606 Views)
02-02-2013 12:25 AM
I don't have a USB port on my tg582n. Am I missing out on any features?
for some reason, my Lg tv finds teh Router, but seems to think there are 3 folders in there: Music; Video; and Pictures!! God know here it is getting that from. I thought possibly froma USB that may bee plugged in, but realised that it doesn't have one!
Thansk
Thansk
Message 4 of 6
(606 Views)
02-02-2013 12:51 AM
Quote from: Timalay
Where is the USB port? theres no standard port on the router that ive been supplied with.
Message 5 of 6
(606 Views)
02-02-2013 2:06 AM
The USB port is present only on the Fibre version of the TG582n.
David
Message 6 of 6
(606 Views)
