582n Firmware version
machare
My Plusnet supplied 582n is running the 8.4.4.I version of the firmware.
I have found versions 8.4.4.J and R10.2.1.8 on the Plusnet website.
What are the benefits of the upgrades? Would it be prudent to upgrade and why might I pick one version rather than the other?
5 REPLIES 5
mushy
Re: 582n Firmware version
I suspect the R10.2.1.8 is for the ADSL version of the router and 8.4.4.J is for the fibre version which i guess you are on from your firmware
I am current on 8.C.M.0 which i got last month when upgrading to fibre, maybe you could ask the PN staff for that version as i would think that is the current one they are shipping out.
Gus
8.4.4.J is on mine so not for fibre, guessing its just the beta version number they use
FTTP 500 regrade from Tues 28th November
machare
Does the 8.4.4.J version support a USB printer?  BE appear to have a version that does that.
I suspect that the R10 version has IPV6
Gus
Mine doesn't have a USB port and no USB options with its web interface, so no
machare
Mine has a port and the CLI accepts printersharing commands.
So far I have not got it to print though!
