38/76mb?
- 38/76mb?
38/76mb?
24-02-2013 1:44 PM
I've had Fibre a couple of weeks, originally went for the 38mb package as the checker said I could get 35mb (estimated).
I'm actually getting 38mb, which is great but I have upgraded to Unlimited now for the extra data.
Can I get any faster speeds? I have a neighbour round the corner on the same cabinet and they are with Plus.net and getting 73mb.
Thanks, Max
Re: 38/76mb?
24-02-2013 1:57 PM
Re: 38/76mb?
24-02-2013 2:21 PM
My thinking is either there is a lock on the line to 38mb or something needs a nudge from their end.
Re: 38/76mb?
25-02-2013 10:14 AM
Re: 38/76mb?
25-02-2013 10:20 AM
What's it say on here for current line speed https://portal.plus.net/my.html?action=data_transfer_speed ?
Mine says:
Phone exchange:
HASLEMERE
Estimated line speed:
66Mb (Accurate to within +/- 1Mbit) - Checked on 2013-01-18 07:15:50
Current line speed:
77.4 Mb
If yours doesn't have something high, support might be needing to change the profile from 40/10 to 80/20 for you.
Re: 38/76mb?
25-02-2013 11:09 AM
Quote from: ricmelia Max, I presume I'm the neighbour your referring to
Yep!
Phone exchange:
HASLEMERE
35Mb (Accurate to within +/- 1Mbit) - Checked on 2013-02-17 15:27:29
Current line speed:
37 Mb
Re: 38/76mb?
25-02-2013 11:22 AM
Mine was "up to 66.4" but I've just checked for where we rented a couple of years ago (at the top of Nappers Wood) - that says "up to 38.4mb", so depending on where you are, maybe 38 is the best you can get :S
Re: 38/76mb?
25-02-2013 1:02 PM
Re: 38/76mb?
25-02-2013 1:10 PM
The estimate might be based on the settled rate that you are now seeing at your property. I can place an order for you to be moved onto the 80/20 product to see if we can get those speeds pushed up for you?
Re: 38/76mb?
25-02-2013 1:24 PM
Re: 38/76mb?
25-02-2013 4:11 PM
Quote from: Chris The estimate might be based on the settled rate that you are now seeing at your property. I can place an order for you to be moved onto the 80/20 product to see if we can get those speeds pushed up for you?
Yes please
Quote from: ricmelia Not sure exactly where you are, but if the BT checker is saying "up to 38.4" for you, I guess your line's a lot longer than mine - mine goes overhead straight down the main road, and we're only two houses in from there.
Mine goes to a pole then who knows!
Re: 38/76mb?
25-02-2013 4:47 PM
Let me know how you get on
Re: 38/76mb?
25-02-2013 6:33 PM
If its changed in my Member Centre does that mean its done? Or just done your end?
Re: 38/76mb?
26-02-2013 9:35 AM
This doesn't reflect if the modify order Chris placed had completed, however it has completed so you should now see the improved speeds.
Re: 38/76mb?
26-02-2013 10:10 AM
Downstream Speed: 64.5 Mbps
Upstream Speed: 20.0 Mbps
