30dB SRNM??????
- Re: 30dB SRNM??????
30dB SRNM??????
09-03-2013 11:43 AM
E-mailed TP-Link tech support regarding some problems and the reply included:
What, using a £10 modem router on a 62dB atten line?
Quote I want to point out that, if the SNRM value is below 10dB, the ISP may need to check the ADSL line (or the modems problem). The normal value is 20dB, and it indicates a good line if it's higher than 30dB.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 1 of 7
(2,058 Views)
6 REPLIES 6
Re: 30dB SRNM??????
11-03-2013 10:45 AM
Hmmmmm....Interesting. Not too sure many of our customers would be happy with 30dB on their line!
Looks like everything is running fine on your connection at the minute
Message 2 of 7
(613 Views)
Re: 30dB SRNM??????
11-03-2013 2:48 PM
That's my thoughts, too
Had to go back to the TG585 as my TP-Link developed a fault where, after a re-sync, the downlink SRNM would be a constant 6dB for a while then oscillate between 4 and 6dB and finally drop steadily from 4dB, holding the connection to 0.8dB The 585 has been at 3dB since I reconnected it and upped the sync to 4Mbps 2.25 days ago
Just to add: this is down to PN getting a new segment of cable ducted to the house
Message 3 of 7
(613 Views)
Re: 30dB SRNM??????
12-03-2013 3:57 PM
Ooh. That might explain the fluctuation in SNR then.
Let us know if you'd like anything looking at
Message 4 of 7
(613 Views)
Re: 30dB SRNM??????
13-03-2013 9:39 AM
Chris, could you adjust/get adjusted my "line speed", please. It's been at 3.1M for a while but my BT profile has been 3.55M for the last 4 days 23 mins and 30 secs (the time I've maintained a sync of more than 4Mbps )
Message 5 of 7
(613 Views)
Re: 30dB SRNM??????
13-03-2013 10:43 AM
I've just nudged that for you
Message 6 of 7
(613 Views)
Re: 30dB SRNM??????
13-03-2013 10:53 AM
Thanks, Chris
Message 7 of 7
(613 Views)
