3 Days and IP Profile not rise at all
- 3 Days and IP Profile not rise at all
02-10-2011 11:29 PM
Re: 3 Days and IP Profile not rise at all
03-10-2011 12:14 AM
03-10-2011 12:17 AM
03-10-2011 1:57 AM
Quote from: Gus You have tried a router reboot? A new IP profile isn't applied till you do.
I had reboot the router just 15 minutes ago and the sync rate had go up to 15693K from 15645K but the IP Profile haven't changing Very disappointed after all these 74 hours and 30 minutes. Look like I had to wait for another 3 days again!
See snapshot (before and after reboot router)
EDIT: after 30 minutes with no profile rise, BT had re-sync the line rate had gone up to 16156K from 15693K and the ip profile haven't changing at all I give up!
EDIT: I switched off the router at 2:30am and leave it off through the night and I will try switch on the router in the morning when I get up.
03-10-2011 11:43 AM
03-10-2011 12:06 PM
03-10-2011 1:11 PM
Quote from: goldenadsl Can plusnet tell me why isn't my line haven't change new ip profile after been connected for 74 hours! Suppose to be changed after 3 days ?
I take it that you have not read up on ADSL, which has been suggested to you on several occasions, if you have done you would have found that updates to profile can take anything from 4 hours to 120 hours depending the percentage change in profile. For me I have experience the 4 hour update several times.
03-10-2011 4:38 PM
The speed was all over the place from 4 meg to 12 meg every 5 minutes
I notice the router had many errors on the downstream side:
SF (CRC) Errors: 11871
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 4382
Errored Seconds: 1280
Severe ES: 201
Interleave Depth: 1
Bitswaps: 355
03-10-2011 5:09 PM
I wouldn't worry about the odd speedtest showing that kind of figure, I've seen that kind of thing on my line many times. As long as it doesn't stick like that is the main thing.
Jojo
03-10-2011 5:12 PM
03-10-2011 5:17 PM
03-10-2011 5:21 PM
I am not happy as I get 4/5/6 meg out of 13000K profile, very poor indeed. Why I get 11.5 Meg on 12000K profile is always spot on every days for 4 days before BT mess my line up again
03-10-2011 5:21 PM
If the faults team thought that was necessary then that would have been done. Unless there was a fault I'm not sure it would be considered. I've said many times on here that if you study your line stats too much you can drive yourself potty, that's why I don't. If I notice particularly prolonged poor performance I will check a few things but otherwise things usually sort themselves out.
Jojo
03-10-2011 5:27 PM
Quote Fault Threshold Rate.
Once your MSR has been set, BTw use this figure to calculate your Fault Threshold Rate which is in the region of 70% of your MSR. BTw will only investigate speed related faults if your speed drops to below the Fault Threshold Level.
Read more: http://www.kitz.co.uk/adsl/maxdsl2.htm#ixzz1ZjjWsdPB
03-10-2011 5:32 PM
