2nd day on FTTC - few questions
Hi everyone.
Had fibre installed yesterday with the netgear router, all going well so far I think.
We were told we should see around 28mb down but so far we are seeing around 20-22mb, does this sound correct?
How long is the training period on the line?
How can I check what the PN IP profile is so I can compare it to the BT one?
My BT fiber modem runs smoking hot, is thatt fairly normal?
Can't think of anything else at the moment!
Thanks!
9 REPLIES 9
Re: 2nd day on FTTC - few questions
The guesstimates BT give are often very wrong... more so that right, so 20-22 sounds reasonable.  Have you tested it with http://speedtester.bt.net ?  And at a quiet time of the day?  At fast speeds factors that slow you down seem to have more of an impact.
Training period I understand is 10 days.... though I'm not sure if that's just the standard line fed to us by CS, or that there is some truth in it.  I suspect with shorter lines the training needed is negliable, and the effects of it tiny.
Log to the PN portal, selecting conneciton settings, and then High Speed Broadband, the profile is shown last on the items there (along with line estimates).  If the speed you are seeing is close to what you had previously with ADSL, the profile at PN's end is the most likely cause.
The BT modem running hot is very common.  Ensure it's wall mounted (it should be), and clear of blockages, radiators, direct sunlight etc. etc.  Even so, posts here have suggested a pretty high mortality rate.
Thankyou!
Wallmount the fibre router?  The BT engineer never mentioned anything about wall mounting it Sad
Wall mounting is highly recommended for the BT Openreach modem.... not the netgear router.
The BT engineer should have done this for you when he did your install.
If not, I highly recommend you do it yourself, as you'll see the vents on it are likely to be more effective when mounted that way, IMHO.
The BT Engineer only said to not put it on carpet.  He was a plusnet customer himself LOL.
Still, if the fibre modem should be wallmounted by the BT engineer then I'm not very happy that he didn't even mention it Sad
Sounds like one of three possibilities:
1) BT doesn't have a consistent policy
2) He wasn't trained correctly, or the training doesn't cover it
3) He couldn't be bothered/disagreed with the training
Your call as to wether you try and find out which above, and get that rectified.... but if I were in your shoes, I'd be popping it on the wall myself.
ATB
Phil
Wall-mounting was certainly never mentioned to me, but I did it anyway as it was in the way and getting very warm where it was. It now runs cool.
Quote from: Chinster
This look about right?
Telephone number:
02828xxxxxx
Phone exchange:
LARNE
Estimated line speed:
3.0Mb (This may vary between 2Mb and 5.5Mb) - Checked on 2011-06-01 18:44:31
Current line speed:
37 Mb
Yes - 37Mb means you're on FTTC, it's the highest value Plusnet uses.
