250Kbps broadband speed
- 250Kbps broadband speed
Re: 250Kbps broadband speed
11-09-2008 10:10 AM
11-09-2008 11:45 AM
That doesn't however affect the speeds at which your line is profiled on. That's all calculated by the sync speeds that you obtain.
I'd defintely try connecting your router (via a filter) to the test socket behind your master faceplate if you have one, and see what sort of sync speed you get that way.
11-09-2008 11:55 AM
http://www.beforum.co.uk/showthread.php?t=8152
http://www.kitz.co.uk/index.htm
http://www.thinkbroadband.com/faq/sections/radsl.html
11-09-2008 11:59 AM
11-09-2008 1:55 PM
11-09-2008 1:59 PM
11-09-2008 9:20 PM
Exchange Information
Distance:- Direct: 5.91 km
(appx)* By Road: 9.82 km
Status
ADSL enabled : July 23, 2003
DSL Max enabled: March 31, 2006
SDSL enabled : Not Enabled
21CN due : (PSTN) Phone No Required
21CN WBC (Broadband) Not available
BT Line Speed Estimation
Fixed ADSL: 2048 kbps (2 Mb)
DSL Max : 5000 kbps (5 Mb)
21CN WBC : Not Available
RAG Test Results
Fixed: 1Mbps and 2Mbps available
radsl: 512Kbps and 256Kbps available
MAX: ADSL Max is available
SDSL: Exchange Not Enabled
TPON: TPON/Fibre not recorded
Check: No info available for this line!
So far (connected to Plusnet last Friday) the Max speed i've got is arround 600kbps am I right in thinking I should be downloading at around 5mb per second?
11-09-2008 10:03 PM
11-09-2008 10:44 PM
My router is a Belkin G+ Mimo F5D9230-4
The modem is a crappy free TalkTalk SmartAX MT882
Thank for any help
12-09-2008 12:24 AM
If your line length from the exchange really is 9.82km (assumed equal to by-road distance) I'm surprised you'd get broadband at all. The BT estimate of 5000kbps normally goes with a line length of about 3.5km.
Also it is important not to confuse download speeds with sync speed. What BT quote are sync speeds, and for sync at 5000kbps the best download speed achievable with optimised PC settings is about 3500kbps.
12-09-2008 1:24 AM
Here are some stats I've pulled from the modem (couldn't find the specific ones mentioned above though):-
ADSL Description
ADSL Status Showtime/Data
DSL Up Time 0:10:58
Data Path Interleaved
Standard G.dmt
Bandwidth Down/Up(kbps) 7616/448
SNR Margin Down/Up(dB) 10.5/20.0
Attenuation Down/Up(dB) 27.0/14.0
CRC Down/Up 2/0
FEC Down/Up 0/0
HEC Down/Up 0/0
PVC: RAS Timer Expired count: 0
Tx Frame(s) count: 1889 Rx Frame(s) count: 2131
Tx Byte(s) count: 550808 Rx Byte(s) count: 2057908
Large Packet(s) Rx count: 0 CIS Rx count: 0
CRC Error(s) count: 0 Invalid CPI SDU count: 0
Invalid PAD count: 0 Invalid Length SDU count: 0
LAN Statistics
Align Error(s) count: 0 FCS Error(s) count: 0
Single Collisn Frame(s) count: 0 Two Collisn Frame(s) count: 0
SQE Test Error(s) count: 0 Deferred Transaction count: 0
Late Collisn count: 0 Excess Collisn count: 0
Internal MAC Rx Error(s) count: 0 Internal MAC Tx Error(s) count: 0
Carrier Sense Error(s) count: 0 Frame Too Long count: 0
Tx count: 2834 Rx count: 2274
Control Pause count: 0 Total Collisn count: 0
12-09-2008 2:08 AM
Quote from: JUICE690 Data Path Interleaved
Standard G.dmt
The values Oldjim mentioned are those, and they are excellent. With a downstream attenuation of 27dB I reckon you must be no more than 2km from your exchange. And with Interleaving turned off should be able to sync at the maximum 8128kbps, but I suggest leaving that for now.
You should be able to download at 5500-6000kbps with those stats. First check that the Plusnet Data Transfer Speed says 6500kbps (the BTw IP Profile corresponding to 7616kbps sync).
I assume your computer connects to the router using wireless; make sure the wireless channel doesn't clash with one used by a neighbour (or checkout 1, 6 and 11 as alternatives).
Does your computer run Windows XP (or earlier)? If so tweaking RWIN (and possibly MTU might be necessary). You could try a tweak test at DSLreports (enter DSL, 8000, {your OS} and Normal to get the results). Please copy and post the URL given in small red letters near the bottom of the page.
12-09-2008 2:42 AM
Here's the link with my results from tweak test:
http://www.dslreports.com/tweakr/block:468cdcb?service=dsl&speed=8000&os=Mac&via=normal
12-09-2008 11:48 AM
The download speed during your tweak test was 1944kbps which is typical for the test site (a test I did a short while ago gave 1907kbps using Windows XP with RWIN=128480 and MTU=1500, sync 7424kbps, and I don't have speed issues). Current result as follows:
What results do you get from the http://www.mybroadbandspeed.co.uk checker?
12-09-2008 8:33 PM
