24 hours since activation no joy!!
beejaycee
No Broadband found.
Ensure your service is active. We'll email and text you when everything's ready.
Verify if your Technicolor Gateway is correctly connected to your DSL line. For more information consult your documentation.
Please close this window and try again.
Keep getting this! Why? It's been 24 hours since i get text saying its activated?! I've tried different filters and routers?
please help, i've been waiting so long for my internet to be switched on!
Fixes: 83
Re: 24 hours since activation no joy!!
Hi beejaycee and welcome to the community forum, I hope you stick around after the issue has been sorted.
Really sorry to see the service isn't working after activation. Line tests show me there's a possible disconnection in the line (usually an exchange issue) I've logged the fault with our suppliers and have updated ticket 78778995 with the particulars.
I hope this gets resolved soon for you.
Adam
 Adam Walker
beejaycee
Hello Adam,
Thank you, when and how can this be fixed? I'm really eager to get online before Christmas day.
Thanks for the swift reply.
Will Grin
beejaycee
Any update?
Fixes: 167
We've got an estimated response time of the 24th December from Openreach, I've updated your ticket with this information too.
 Chris Parr
 Plusnet Staff
beejaycee
Thank you, really eager to get online
Pettitto
Fixes: 5
You should be up and running now Smiley
beejaycee
Hi Chris, yes had a guy round today to sort it, just trying to connect now but still getting a few errors.
Other then typing in the wifi password what other steps do i have to do? Im doing what it says in the welcome to plusnet guidebook? I have the Technicolour router but also have tried a TP-link router and still no network access? Am i missing something?
Pettitto
Fixes: 5
If you connect the router we sent you, are you able to connect with an Ethernet Cable in the first instance?
beejaycee
Ill try connecting with a ethernet cable now with my laptop, the internet light is off at the moment
beejaycee
Okay so the broadband light is solid now, the Ethernet light is flashing but getting not network access via both connection types Undecided
Pettitto
Fixes: 5
Ok. That's a bit odd. What happens if you try and visit http://192.168.1.254
I know it says you have No Network Access but I find that the message can sometimes not be up to date.
beejaycee
Saying an authentication error?
DNS Spoofed is in the URL if that's of any help
beejaycee
Whilst logging in i am only to use the password and username that came with the router right? Not any of my Plusnet credentials?
Pettitto
Fixes: 5
If you look on the back of the router, there's a small hole (it should say 'Reset') get a pin/paper clip push and hold it into that hole for 10 seconds and give your router 5 minutes to boot itself back up.
