21CN WBC enabled now (I think), probably need a new router
- 21CN WBC enabled now (I think), probably need a ne...
10-09-2012 2:36 PM
Exchange was due for an upgrade. It may have happened this morning (looking at my stats). My Billion 7800N broke so I am back on my Linksys WAG54GS (v.1 I think); I don't think this router is ADSL2 compatible.
The Billion had a much higher attenuation (+5) than the WAG but also had a very marginally better dl; as all I ever read is higher attenuation is worse it is a little confusing.
Sooooo the question is, which router should I look at next?
Opinions if you care to share!
I'm not interested in the Thompson thank you!!!
[edit]
I can't attach my line stats as an acceptable type right now. ADSL2 framing is mentioned which wasn't there last time I looked. My D SNR is lower than usual- usually around 9.
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: Showtime Channel: INTR, Upstream rate = 448 Kbps, Downstream rate = 364
8 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Interleave
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 5.8 18.0
Attn(dB): 58.5 31.5
Pwr(dBm): 18.6 12.3
Max(Kbps): 3936 996
Rate (Kbps): 3648 448
G.dmt framing
K: 115(0) 15
R: 16 16
S: 2 8
😧 16 4
ADSL2 framing
MSGc: 1 1
B: 94 15
M: 2 8
T: 1 1
R: 16 16
S: 2.1684 9.0000
L: 760 128
😧 16 4
Counters
SF: 406387 406385
SFErr: 87 0
RS: 13817178 3454272
RSCorr: 5281 0
RSUnCorr: 854 0
HEC: 81 0
OCD: 1 0
LCD: 0 0
Total Cells: 59439894 0
Data Cells: 3507671 0
Drop Cells: 32
Bit Errors: 0 0
ES: 897 0
SES: 1 0
UAS: 27 0
Total time = 1 days 19 hours 28 min 55 sec
SF = 80374686
CRC = 2096
LOS = 0
LOF = 0
ES = 897
Latest 1 day time = 19 hours 28 min 55 sec
SF = 4124515
CRC = 120
LOS = 0
LOF = 0
ES = 66
Latest 15 minutes time = 13 min 55 sec
SF = 49108
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 15 minutes time = 15 min 0 sec
SF = 52989
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 1 day time = 24 hours 0 sec
SF = 5082321
CRC = 270
LOS = 0
LOF = 0
ES = 120
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52930
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52931
CRC = 82
LOS = 0
LOF = 0
ES = 37
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52930
CRC = 3
LOS = 0
LOF = 0
ES = 2
[edit]
8 Kbps
Mode: G.DMT
Channel: Interleave
Trellis: ON
Down Up
SNR (dB): 5.8 18.0
Attn(dB): 58.5 31.5
Pwr(dBm): 18.6 12.3
Max(Kbps): 3936 996
G.dmt framing
K: 115(0) 15
R: 16 16
S: 2 8
😧 16 4
ADSL2 framing
MSGc: 1 1
B: 94 15
M: 2 8
T: 1 1
R: 16 16
S: 2.1684 9.0000
L: 760 128
😧 16 4
Counters
SF: 406387 406385
SFErr: 87 0
RSCorr: 5281 0
RSUnCorr: 854 0
HEC: 81 0
OCD: 1 0
LCD: 0 0
Drop Cells: 32
Bit Errors: 0 0
ES: 897 0
SES: 1 0
UAS: 27 0
SF = 80374686
CRC = 2096
LOS = 0
LOF = 0
ES = 897
SF = 4124515
CRC = 120
LOS = 0
LOF = 0
ES = 66
SF = 49108
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 52989
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 5082321
CRC = 270
LOS = 0
LOF = 0
ES = 120
SF = 52930
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 52931
CRC = 82
LOS = 0
LOF = 0
ES = 37
SF = 52930
CRC = 3
LOS = 0
LOF = 0
ES = 2
Message 1 of 3
(1,102 Views)
2 REPLIES 2
Re: 21CN WBC enabled now (I think), probably need a new router
10-09-2012 2:42 PM
With that reported attenuation you will be on ADSL1 as is shown by the router stats so unless you really want to buy a new router I wouldn't bother as you are most unlikely to see any improvement
Note that for your attenuation your speeds are very good
Message 2 of 3
(334 Views)
10-09-2012 4:30 PM
Disappointing but not entirely unexpected.
Message 3 of 3
(334 Views)
