*21CN ONLY* Do you think your PN profile is not updating as it should?
- *21CN ONLY* Do you think your PN profile is not up...
Re: *21CN ONLY* Do you think your PN profile is not updating as it should?
28-02-2012 9:36 PM
I've just changed your profile to 3800 so you should see that increase shortly, normally about 15 minutes.
Jojo
28-02-2012 9:39 PM
28-02-2012 9:46 PM
29-02-2012 1:05 AM
Quote from: _Adam_Walker_ Hi, we'll need to speak to Jojo about that, she's on leave today but I'll drop her a message to have a look at this on Monday.
Adam
So that must be a no then?
29-02-2012 8:54 AM
I'll see if I can find out any more today.
Jojo
29-02-2012 1:24 PM
PN profile 2.6k
old ticket number linked to my account: 51284249
Has been for last 4 days, I have rebooted my router three times once a day during daytime to see if its changed and not yet.
01-03-2012 9:45 AM
I've updated the profile for you as that's at 2.7mb on BT's side at present.
I've also submitted an SNR reset to see if we can get the IP profile to increase, that should take effect within the next 24 hours.
01-03-2012 10:04 AM
So other than the 2 resyncs I had there is little or no change
edit: current state of play
Download speedachieved during the test was - 2.69 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.33 Mbps
edit take 2, did a manual reboot. PN still showing 2.7 as current line speed
But better speeds
01-03-2012 1:25 PM
02-03-2012 9:48 AM
Download speedachieved during the test was - 17.45 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 18.63 Mbps
Can my Plusnet profile be pushed upwards? I know it is only a small change, but it would be greatly appreciated.
02-03-2012 2:47 PM
Your sync is now 5912, so I have raised your profile to 5200 to allow for your new BT IP profile. This should take effect shortly.
Jojo
04-03-2012 11:30 AM
Was upgraded from 'up to 8Mbps' to 'up to 20Mbps' on around the 21st Feb..... immediately got a downstream sync of around 13Mbps..... having previously tweaked my SNR on my router (Billion 7800N), I thought it best to reset to factory default with the new service - sync went down to 11Mbps.... Plusnet "high speed broadband" reported my "Current line speed" as "7.15 Mb" (as I used to get on the old 8Mbps service with the tweaked SNR).
Decided to wait 10 days (assumed training period with new service was still the same), and various speed tests over the next 9 days showed that throughput remained capped at 7.15Mbps, even with the higher sync. A BT speed test on 25th Feb. indicated that the BT IP Profile was 10.46Mbps....... Modem sync also went up to around 13Mbps during this time, but throughput remained at 7Mbps-ish....
This morning (10th day after upgrade?) a generic throughput test ("mybroadbandspeed.co.uk") reported:
Today 10:56 10478 kbps (1.31MB/s) 540 kbps (67.5kB/s)
A BT speedtest reported:
Download speed achieved during the test was - 11.19 Mbps
IP Profile for your line is - 11.8 Mbps
However, in my Plusnet Member Centre, my "Current line speed" is still being reported as 7.15 Mb.
As I'm no longer being capped at 7.15Mbps, not sure if this is exactly the same situation as others that have posted, but there's still the discrepancy between BT IP Profile and Plusnet reported speed.......
Does my Plusnet profile need a kick, even if it's only to get everything in sync...?? And if I start tweaking my SNR in my router (which worked with the 8Mbps service - modem sync went from less than 7Mbps to 8128kbps solid), does it still look like I would need to revisit (here, or raise a ticket) to get the PN speed updated.....
Thanks,
P.
04-03-2012 2:48 PM
Been upgraded to FFTC a week ago and my ip profile is 37.42mbps however my plusnet profile is 21mbps
04-03-2012 7:53 PM
My line was enabled for ADSL2+ on Monday last week, and has been hovering around 8000 - 9000 kbps ever since, however my PlusNet "Current Line Speed" figure is still at 5.5Mb (which was my pre-ADSL2+) IP profile.
See below for my current line stats and also the attached file for a recent BT speedtest - On the plus side, the DSLAM seems to have decided that my line is stable enough for a 3 db noise margin too, which seems to be holding up fairly well *touch wood*
Downstream
Speed: 8826 kbps
Attenuation: 40 db
Noise Margin: 3.7 db
Upstream
Speed: 798 kbps
Attenuation: 21.7 db
Noise Margin 5.2 db
Can my PlusNet profile possibly be upped to match my actual IP profile?
Cheers
05-03-2012 4:33 PM
@Pawhe955 - likewise changed to 11800
@granilith - I believe I've resolved your issue on the thread you started? Please let me know if not.
@Alphaseven - Your profile has been changed to 8800.
I hope this sorts it all for everyone and that speeds improve Please let us know if not or if there's anything else we can do.
