*21CN ONLY* Do you think your PN profile is not updating as it should?
- *21CN ONLY* Do you think your PN profile is not up...
Re: *21CN ONLY* Do you think your PN profile is not updating as it should?
07-05-2013 2:30 PM
07-05-2013 2:37 PM
I thought similar when I looked, but the times will actually avoid most instances where OR etc may be working on lines, end users connections and so on, so temporary poor results whilst work is in hand won't get propagated. Of course those on 21CN will benefit most, 20CN users are still stuck with lengthy BT IP Profile update times though unless [dreaming] ....
Maybe BT generate Delta reports more frequently, just not propagating them to Plusnet except at the stated times.
Anyway that's my theory, I don't know if any of the Chris's can enlighten us -
07-05-2013 3:13 PM
07-05-2013 3:20 PM
07-05-2013 3:23 PM
07-05-2013 3:37 PM
07-05-2013 3:43 PM
07-05-2013 3:44 PM
Thanks for the detailed replies.
07-05-2013 3:54 PM
07-05-2013 4:27 PM
07-05-2013 4:28 PM
If BT generate delta reports throughout the day within an hour of a resync, I can't see why you are not updating your side during the day. For anyone powering up their router at the start of the day, say between 8am and 10am and powering off around teatime it guarantees their current line speed will be wrong for most of the time, OK from day to day it is likely to be similar, but it will rarely be right.
Given that a lot of people are at work during the day and so won't be rebooting routers, and lines are generally more stable during the day so won't be resyncing because the noise margin has gone low, the number of events is going to be lower during the day anyway. So it can't be because of avoiding the processing load during the day. All you are doing is triggering a lot of current line speed updates at the very time lots of people will be going on-line (18:05).
07-05-2013 4:29 PM
Quote from: Anotherone Blimey, you are doing well to hold that speed if you have that 1db margin all the time. I suppose that says something about the DGND3700v2
Yes it been holding steady 1dB for five days! That router is pretty good.
07-05-2013 5:00 PM
Quote from: jelv It was the 0:05, 3:05, 6:05, 17:05, 20:05 that I was querying.
The scripts that run do process a LOT of data, it's something that we are looking at though. The reason that it isn't done this way at present is due to load amount with everything else that is running during the day and being used, this can have an impact on our systems across our support centre.
07-05-2013 5:05 PM
07-05-2013 5:33 PM
