*21CN ONLY* Do you think your PN profile is not updating as it should?
jojopillo
Re: *21CN ONLY* Do you think your PN profile is not updating as it should?
Hi Graham,
I've upped that to 18700 on our side for you. You should see that in the next 15 mins or so.
Jojo Smiley
GrahamC
Thanks JoJo
Looks like the reset caused the connection to hop over to another gateway - pcl-ag06 and is giving some wierd speedtest results at the mo. I'll try and hop onto another see if it will settle.
cheers
Graham
grudkin
I have had a sync rate of 18112kbps resulting in a BT IP profile of 15.98 Mbps for over 4 days now but the plusnet profile still reports a Current line speed of 15.6 Mb.
Am I the only one that thinks that after over 6 months, Plusnet really should have solved the problem of the plusnet profile not updating properly on ADSL2+ by now!  Roll_eyes
orbrey
The BT profile is showing as being updated two days ago on the 26th, so ours should have updated at some point today for you - sorry that it didn't update earlier. I've set it to 16000 on our side so you should get that extra 300kbit now, hope that helps.
grudkin
Thanks Matt!
However I don't understand why the BT profile is only showing as updated on the 26th when the BT speedtester was reporting a profile of 15.98 Mbps since the 22nd with no drops until my router decided to reboot itself last night for no reason resulting in a slightly lower IP Profile of 15.82 Mbps after!  Crazy
orbrey
We get the reports from WCR which is another part of BTs systems, however this is also the system that gives us the updates on customer speed profiles and might account for at least some of the delay.
zuchov1
My line was upgraded on Monday afternoon. Here are the router stats:
Uptime:  0 days, 1:04:42
DSL Type:  G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]:  888 / 23,444
Bandwidth (Up/Down) [kbps/kbps]:  440 / 21,522
Data Transferred (Sent/Received) [MB/MB]:  6.20 / 35.38
Output Power (Up/Down) [dBm]:  10.5 / 20.0
Line Attenuation (Up/Down) [dB]:  3.5 / 5.5
SN Margin (Up/Down) [dB]:  30.0 / 9.0
Vendor ID (Local/Remote):  TMMB / IFTN
Loss of Framing (Local/Remote):  0 / 0
Loss of Signal (Local/Remote):  0 / 0
Loss of Power (Local/Remote):  0 / 0
Loss of Link (Remote):  0
Error Seconds (Local/Remote):  0 / 0
FEC Errors (Up/Down):  0 / 3,891
CRC Errors (Up/Down):  0 / 3
HEC Errors (Up/Down):  0 / 127
But my download speed has not changed. Here is my Plusnet profile:
Estimated line speed:
8Mb (Accurate to within +/- 1Mbit) - Checked on 2012-05-28 17:52:58
Current line speed:
6.5 Mb
Any solutions?
Thanks.
jelv
Fixes: 10
You need to run the BT speedtest and confirm what it says for your IP Profile. You can then ring PN (or post on here) to ask for your current line speed to be set to match.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
zuchov1
Completed speed test:
Download speedachieved during the test was - 5.64 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 18.99 Mbps
jelv
Fixes: 10
That confirms it's just the PN current line speed that is holding you back - hopefully one of the Digital care Team will see this soon and do what is needed.
BTW: Do you live in a flat above the exchange? I don't think I've ever seen an attenuation as low as yours (it goes up the further you are from the exchange). I'd expected to see very few FEC errors which would mean that interleaving off would be safe and you'd get an even faster sync.
zuchov1
I live approx. 0.2 miles from the exchange. The above results were taken not long after I turned the router on/off.
Here are some more stats after 17+ hours.
Uptime: 0 days, 17:37:57
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 23,468
Data Transferred (Sent/Received) [MB/GB]: 489.06 / 2.68
FEC Errors (Up/Down): 36,032 / 49,504
CRC Errors (Up/Down): 1,281 / 43
HEC Errors (Up/Down): 1,818,558,464 / 675
jelv
Fixes: 10
That's a lot of errors! Have you got multiple telephone sockets? If so I'd like to see if it's still clocks errors when it's in the test socket inside the master socket which isolates all the internal wiring and the other sockets.
jojopillo
Hi zuchov1,
I have raised your profile to 18900 to allow for your new BT IP profile. This should take effect shortly.
Jojo Smiley
zuchov1
Download speed has increased to:
jojopillo
Nice Smiley
