*21CN ONLY* Do you think your PN profile is not updating as it should?
- Re: *21CN ONLY* Do you think your PN profile is no...
Re: *21CN ONLY* Do you think your PN profile is not updating as it should?
23-01-2012 12:37 PM
I suggest reading this thread again as I fully documented the problem http://community.plus.net/forum/index.php/topic,99337.0.html including a file download test from TBB
Quote from: Joanne Thanks guys,
I'll continue to collect them until it's sorted. Also, as far as getting higher than our profile, I'm not convinced. I've seen these kind of results before and they do tend to be anomalies. Mind you, if you're happy then I'm not going to burst your bubble
Jojo
23-01-2012 1:29 PM
Sorry I missed your earlier post, I have raised your profile to 19000 to allow for your new BT IP profile. This should take effect shortly.
@oldjim,
Still think it's an anomaly or we'd be seeing a lot more of it. Besides which, Dave said it's not possible.
Jojo
23-01-2012 1:36 PM
26-01-2012 8:47 AM
Line Sync = 12498 Kbps
BT profile = 11026 Kbps
Plusnet line speed = 5.8 Mb
Uptime = 72+ hours
Speed tests are consistent with the Plusnet line speed.
Regards......Paul
26-01-2012 8:58 AM
I've just set your profile to 11000 to match your BT IP profile, you should see the increase shortly.
Jojo
26-01-2012 9:00 AM
Quote from: Joanne dfunked and billnotben, thanks for the examples.
caulbox, glad it's performing well now.
Quote from: caulbox Do I escape the cut with a 77 and the last two rounds remaining?
Please don't use golf terminology, it's likely to confuse me!
Jojo
For the record, mine took just over 7 days to match the IP profile. Not really that bad if you're just waiting for a minute change (3.6 to 3.7 in my case), but I can imagine it would be pretty damn annoying if you were waiting for a bigger change!
26-01-2012 9:02 AM
Quote from: dfunked but I can imagine it would be pretty damn annoying if you were waiting for a bigger change!
I'm hoping to have a bit more information by the end of today.
Jojo
26-01-2012 9:08 AM
Thanks Jojo.. Speedtests now as they should be.
Connection just dropped. Was that you or a coincidence?
Thanks.
26-01-2012 9:10 AM
Not sure if I'm jumping the gun with this one as my BT profile only changed about 20 hours ago, but having had trouble before I thought this might be of use to you.
Yesterday I updated the software in my router and the downstream speed went from 6819 to 7611. The BT profile immediately went up to 6715 (from just over 6000), and I hoped the PN profile would move up from 6.0 overnight, but it hasn't. If you think I should wait for more time OK, but if not a push from you would be appreciated!
Alan
26-01-2012 9:14 AM
The PPP session will have dropped with me changing the profile so you could pick up the new speed.
Jojo
26-01-2012 9:18 AM
I have raised your profile to 6700 to allow for your new BT IP profile. This should take effect shortly.
Jojo
26-01-2012 9:25 AM
26-01-2012 10:04 AM
Quote from: Oldjim I suggest reading this thread again as I fully documented the problem http://community.plus.net/forum/index.php/topic,99337.0.html including a file download test from TBB
Jojo
I'm confident that I have also had download speeds higher than Plusnet profile. Reason I'm confident is that various download rate montors and speedtest sites gave corresponding figures at those times. Tended to be following re-sync that resulted in higher connection speed but PN profile not changing.
26-01-2012 5:02 PM
I've just been speaking to our suppliers and I've some news. They have identified the issue and are initiating a fix for it. Sadly, it's not a simple one and will take a number of weeks to implement.
In the meantime I'll be happy to change anyone manually, although I'd appreciate it if it wasn't on a daily basis, unless, of course it's severely impeding your speed.
Thank you all for providing me with the examples and I'll update here when we get an idea as to when it will be resolved.
Jojo
26-01-2012 5:53 PM
